Hello,
First of all, this post is not to provide an open issue, but I propose a solution for a known error. My problem is exactly the same problem described at https://www.ghielectronics.com/community/forum/topic?id=9995,
and there is a same error code (7).
[em]Using mainboard GHI Electronics FEZSpider version 1.0
RS9110 firmware version Number is 4.4.5
RS9110 driver version Number is 4.4.5
Exception System.Exception - 0x00000000 (1)
Message:
GHI.Premium.Net.RS9110Helper::Join [IP: 003b]
GHI.Premium.Net.WiFiRS9110::Join [IP: 008b]
MWS.Micro.Core.Network.WifiNetworkManager::Connect [IP: 008f]
MultipleTimeZoneClock.Program::ProgramStarted [IP: 0051]
Exception GHI.Premium.Net.NetworkInterfaceExtensionException - 0x00000000 (1)
Message:
GHI.Premium.Net.WiFiRS9110::Join [IP: 00e7]
A first chance exception of type ‘GHI.Premium.Net.NetworkInterfaceExtensionException’ occurred in GHI.Premium.Net.dll[/em]
In this post the author has found a solution by the following way:
[em]Paul F.Senior with 1,275 exp1 year ago #6
Update, I was actually able to successfully “Join” after changing my wireless router to use WPA for wireless security, instead of WEP.
My router is a D-Link (DI-624)[/em]
My problem comes from wireless router security. My solution is to change my wireless router to WPA(AES/CCMP) instead of WPA(TKIP/AES).
My Router is FreeBox V6, Im from PARIS.
Hope my help for everyone.
Best regards,
