Found debugger!
Create TS.
Loading start at 202d8818, end 20307cac
Assembly: mscorlib (4.3.1.0) Assembly: Microsoft.SPOT.Native (4.3.1.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.3
.1.0) Assembly: System.Security (4.3.1.0) Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0) Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0) Assembly: System.IO (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0) Assembly: Microsoft.SPOT.Touch (4.3.1.0)
Assembly: Microsoft.SPOT.Ink (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Attaching deployed file.
Assembly: MFConsoleApplication1 (1.0.0.0) Attaching deployed file.
Assembly: System (4.3.1.0) Attaching deployed file.
Assembly: GHI.Networking (4.3.6.0) Attaching deployed file.
Assembly: GHI.Hardware (4.3.6.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.3.1.0) Resolving.
GC: 1msec 223512 bytes used, 66882252 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 66882252 bytes
Type 17 (ASSEMBLY ): 27108 bytes
Type 1E (BINARY_BLOB_HEAD ): 196308 bytes
GC: performing heap compaction…
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Security.PKCS11.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Graphics.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.TinyCore.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Touch.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Ink.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.3 SDK\Libraries\le\GHI.Hardware.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.3 SDK\Libraries\le\GHI.Networking.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘c:\users\alexey\documents\visual studio 2012\Projects\MFConsoleApplication1\MFConsoleApplication1\bin\Release\le\MFConsoleApplication1.exe’, Symbols loaded.
Step into: Stepping over non-user code ‘GHI.Networking.WiFiRS9110.WiFiRS9110’
Step into: Stepping over non-user code ‘GHI.Networking.BaseInterface.BaseInterface’
Step into: Stepping over non-user code ‘Microsoft.SPOT.Net.NetworkInformation.NetworkChange.NetworkAddressChanged.add’
Step into: Stepping over non-user code ‘Microsoft.SPOT.Net.NetworkInformation.NetworkChange.NetworkAvailabilityChanged.add’
Step into: Stepping over non-user code ‘GHI.Networking.BaseInterface.RefreshNetworkInterface’
Step into: Stepping over non-user code ‘Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces’
Step into: Stepping over non-user code ‘Microsoft.SPOT.Hardware.OutputPort.OutputPort’
Step into: Stepping over non-user code ‘GHI.Networking.WiFiRS9110.UpdateInternalMacAddress’
Step into: Stepping over non-user code ‘GHI.Networking.WiFiRS9110.Reset’
Step into: Stepping over non-user code ‘GHI.Networking.WiFiRS9110.WaitOn’
Step into: Stepping over non-user code ‘GHI.Networking.WiFiRS9110.RecoverFromHardwareException’
