My RS21 has stopped working for some reason. I have no idea what caused it. No hardware changed and no code changed that related to the WiFi module.
The program has been working for some time without problems.
I think something happened to the WiFi firmware and needs refreshing but I have not been able to get the wifi_RS21.Interface.UpdateFirmware() to work.
But then again, I cannot find anything that shows what code is required to make it ‘do it’s thing’… I have tried but have not been successful.
So I am asking for one of the GHI software Gurus for help. Besides I would think this should be provided in print somewhere…
I receive two different errors depending I the code I have tried.
wifi_RS21.Interface.IsLinkConnected
'wifi_RS21.Interface.IsLinkConnected' threw an exception of type 'GHI.Premium.Net.NetworkInterfaceExtensionException'
bool {GHI.Premium.Net.NetworkInterfaceExtensionException}
errorCode 12 GHI.Premium.Net.NetworkInterfaceExtensionException.ErrorCode {int}
I believe this is 'HardwareCommunicationTimeout'
It means that the system could communicate with the WiFi module but
it did not get the expected initialization response.
This happens when the WiFi module firmware is corrupted.
The firmware can be updated using WiFi FirmwareUpdate() method.
Using mainboard GHI Electronics FEZSpider version 1.0
Program Started
The thread '<No Name>' (0x3) has exited with code 0 (0x0).
Start Updating WiFi module firmware:
This might take up to 1 minute
0 Sec
1 Sec
2 Sec
3 Sec
4 Sec
5 Sec
98 Sec
99 Sec
RS9110 firmware update failed: Time out
#### Exception GHI.Premium.Net.NetworkInterfaceExtensionException - 0x00000000 (1) ####
#### Message:
#### GHI.Premium.Net.WiFiRS9110::UpdateFirmware [IP: 006a] ####
#### KindleWifiSpeakSpider.Program::updateWiFiModule [IP: 000b] ####
#### Gadgeteer.Modules.GHIElectronics.Button::OnButtonEvent [IP: 0058] ####
#### Gadgeteer.Modules.GHIElectronics.Button::_input_Interrupt [IP: 0068] ####
#### Gadgeteer.Interfaces.InterruptInput::OnInterruptEvent [IP: 0055] ####
#### System.Reflection.MethodBase::Invoke [IP: 0000] ####
#### Gadgeteer.Program::DoOperation [IP: 001a] ####
#### Microsoft.SPOT.Dispatcher::PushFrameImpl [IP: 0054] ####
#### Microsoft.SPOT.Dispatcher::PushFrame [IP: 001a] ####
#### Microsoft.SPOT.Dispatcher::Run [IP: 0006] ####
#### Gadgeteer.Program::Run [IP: 0020] ####
A first chance exception of type 'GHI.Premium.Net.NetworkInterfaceExtensionException' occurred in GHI.Premium.Net.dll
Error invoking method "Gadgeteer.Interfaces.InterruptInput" (check arguments to Program.BeginInvoke are correct)
// With a different approach I receive...
try
wifi_RS21.Interface.UpdateFirmware();
catch (SystemException)
//The System exception received is NOT caught here
Program Started. Press button to begin.
RS9110 firmware version Number is 4.4.5
RS9110 driver version Number is 4.4.5
0 Sec
1 Sec
2 Sec
//Long delay here 5/10 seconds
3 Sec
4 Sec
5 Sec
#### Exception System.Exception - 0xffffffff (5) ####
#### Message:
#### GHI.Premium.Net.RS9110Helper::QueryConnectionStatus [IP: 0000] ####
#### GHI.Premium.Net.RS9110Helper::CheckForEvent [IP: 001e] ####
An unhandled exception of type 'System.Exception' occurred in GHI.Premium.Net.dll
As of now. my Module is useless… Sad here…
But I’ll assume you really mean there was no change and move past that…
