My WiFi_RS21 module seems to be joining my WiFi network ok in that the Join method executes without throwing an exception but as soon as I try and assign the interface a static IP address (I tried DHCP as well but had similar problems) I do get an exception.
wifi_RS21.NetworkDown += new GT.Modules.Module.NetworkModule.NetworkEventHandler(wifi_NetworkDown);
wifi_RS21.NetworkUp += new GT.Modules.Module.NetworkModule.NetworkEventHandler(wifi_NetworkUp);
//wifi_RS21.UseDHCP();
wifi_RS21.Interface.Open();
NetworkInterfaceExtension.AssignNetworkingStackTo(wifi_RS21.Interface);
// look for avaiable networks
var scanResults = wifi_RS21.Interface.Scan();
WiFiNetworkInfo myNetwork = null;
// go through each network and print out settings in the debug window
foreach (var result in scanResults)
Debug.Print("****" + result.SSID + "****");
Debug.Print("ChannelNumber = " + result.ChannelNumber);
Debug.Print("networkType = " + result.networkType);
//Debug.Print("PhysicalAddress = " + GetMACAddress(result.PhysicalAddress));
Debug.Print("RSSI = " + result.RSSI);
Debug.Print("SecMode = " + result.SecMode);
if (result.SSID == WIFI_NETWORK)
myNetwork = result;
if (myNetwork != null)
wifi_RS21.Interface.Join(myNetwork, WIFI_PASSWORD);
Debug.Print("Network joined");
wifi_RS21.UseStaticIP("10.1.1.25", "255.255.255.0", "10.1.1.1", new string[] { "10.1.1.1" });
The output from the debugger is:
[quote]Using mainboard GHI Electronics FEZSpider version 1.0
Program Started
Camera now connected
RS9110 firmware version Number is 4.4.5
RS9110 driver version Number is 4.4.5 aza
ChannelNumber = 6
networkType = 1
RSSI = 46
SecMode = 2
Network joined
#### Exception System.NullReferenceException - CLR_E_NULL_REFERENCE (1) ####
#### Message:
#### Gadgeteer.Modules.Module+NetworkModule::UseStaticIP [IP: 000f] ####
#### GadgeteerApp4.Program::t_Tick [IP: 011c] ####
#### Gadgeteer.Timer::dt_Tick [IP: 0018] ####
#### Microsoft.SPOT.DispatcherTimer::FireTick [IP: 0010] ####
#### Microsoft.SPOT.Dispatcher::PushFrameImpl [IP: 0054] ####
#### Microsoft.SPOT.Dispatcher::PushFrame [IP: 001a] ####
#### Microsoft.SPOT.Dispatcher::Run [IP: 0006] ####
#### Gadgeteer.Program::Run [IP: 0020] ####
A first chance exception of type ‘System.NullReferenceException’ occurred in Gadgeteer.dll
Exception performing Timer operation
Network Up event; state = Down[/quote]
Not sure about Join but I ‘Think’ it also happened to me using Join.
I DO KNOW that it happened to me on Connect
Partial code Snip…
//Using GHI .NET Micro Framework 4.2
void StartWIFI()
if (!wifi_RS21.Interface.NetworkInterface.IsDhcpEnabled)
wifi_RS21.Interface.NetworkInterface.EnableDhcp();
wifi_RS21.Interface.WirelessConnectivityChanged +=
new WiFiRS9110.WirelessConnectivityChangedEventHandler(Interface_WirelessConnectivityChanged);
wifi_RS21.Interface.NetworkAddressChanged +=
new WiFiRS9110.NetworkAddressChangedEventHandler(Interface_NetworkAddressChanged);
WiFiRS9110.AssignNetworkingStackTo(wifi_RS21.Interface);
try
WiFiNetworkInfo[] ScanResp = wifi_RS21.Interface.Scan(ssid);
//Use to Scan for all SSID's
//WiFiNetworkInfo[] ScanResp = wifi_RS21.Interface.Scan( );
if (ScanResp != null && ScanResp.Length > 0)
//Your passkey needed here
wifi_RS21.Interface.Join(ScanResp[0], PassKey);
if (useDebug) { Debug.Print("Connected to Wireless network - " + ssid); }
if (useDebug) { Debug.Print("Failed to connect to Wireless network - " + ssid); }
catch (Exception e)
Debug.Print("!!Exception : " + e.Message);
ipep = new IPEndPoint(IPAddress.Parse(ip), port);
AndroidSocket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
//Exception on Connect(ipep) if a delay is not used?
//Exception using 1000, 2000,
//3000 seemed to work without an exception,, So I'll use 4000 ;>)
Thread.Sleep(4000);
AndroidSocket.Connect(ipep);
//Inform user that connection was successful
multicolorLed.TurnGreen();
//Send a greeting message to the Android device
data = Encoding.UTF8.GetBytes("Hello from the Fez Spider.");
//Send greeting to the Android Tablet
AndroidSocket.Send(data);
//ReceiveDataThread = new Thread(ReceiveData);
//ReceiveDataThread.Start();
Readtimer = new Timer(new TimerCallback(ReceiveData), null, 100, 500);
See my comments in code above
//3000 seemed to work without an exception, So I’ll use 4000 ;>)
Thread.Sleep(4000);
ERROR WITHOUT Delay added shown below.
No error with Thread.Sleep(4000); added
I do not know why the delay is needed but adding it solved my problem. (Took me hours to solve)
Frankly, I just added the delay on a wild thought…
#### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (1) ####
#### Message:
#### Microsoft.SPOT.Net.SocketNative::poll [IP: 0000] ####
#### System.Net.Sockets.Socket::Poll [IP: 0011] ####
#### System.Net.Sockets.Socket::Connect [IP: 0029] ####
#### AndroidWifiSpider.Program::StartWIFI [IP: 010b] ####
#### AndroidWifiSpider.Program::Startbutton_ButtonPressed [IP: 004d] ####
#### Gadgeteer.Modules.GHIElectronics.Button::OnButtonEvent [IP: 0058] ####
#### Gadgeteer.Modules.GHIElectronics.Button::_input_Interrupt [IP: 0068] ####
#### Gadgeteer.Interfaces.InterruptInput::OnInterruptEvent [IP: 0055] ####
#### System.Reflection.MethodBase::Invoke [IP: 0000] ####
#### Gadgeteer.Program::DoOperation [IP: 001a] ####
#### SocketException ErrorCode = 10050
A first chance exception of type ‘System.Net.Sockets.SocketException’ occurred in Microsoft.SPOT.Net.dll
Error invoking method “Gadgeteer.Interfaces.InterruptInput” (check arguments to Program.BeginInvoke are correct)
The delay was indeed part of my problem although the thing which threw me is getting a NetworkUp event with a state of Down.
I guess that’s normal and the state refers to the IP address allocation or something above the physical level.
Thanks to willgeorge’s sample I was able to get up and running and the wifi_RS21.Interface.NetworkAddressChanged event was the key one to know that the WiFi adapter is actually working and ready to start doing something with.
