Im trying to run the WiFi Demo:
IM getting this output:
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.System.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Net.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.Net.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\System.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘c:\users\oki\documents\visual studio 2010\Projects\WifiDemo\WifiDemo\bin\Debug\le\FEZ Cobra Console Application.exe’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\FEZCobra_GHIElectronics.NETMF.FEZ.dll’
Version Number is 4.3.0
#### Exception GHIElectronics.NETMF.Net.WiFi+HardwareException - 0x00000000 (1) ####
#### Message:
#### GHIElectronics.NETMF.Net.WiFi::Enable [IP: 008d] ####
#### RTIP_RedPine_test.Program::Main [IP: 001b] ####
A first chance exception of type ‘GHIElectronics.NETMF.Net.WiFi.HardwareException’ occurred in GHIElectronics.NETMF.Net.dll
#### Exception System.Exception - 0xffffffff (1) ####
#### Message:
#### GHIElectronics.NETMF.Net.RS21Driver::SetBootloadOption [IP: 0000] ####
#### GHIElectronics.NETMF.Net.WiFi::UpdateFirmware [IP: 0027] ####
#### RTIP_RedPine_test.Program::Main [IP: 0045] ####
A first chance exception of type ‘System.Exception’ occurred in GHIElectronics.NETMF.Net.dll
An unhandled exception of type ‘System.Exception’ occurred in GHIElectronics.NETMF.Net.dll
220uF electrolyte + .47 uF).
