Hello,
I’m using a wifi expansion module of Olimex with an zg2100 compatible Wifi module on it and a UEXT connector.
I have connected to UEXT connector on the Fez Cobra board and uses the example programm of GHI at the Wifi Class
using System.Net;
namespace WiFi_Example4._0
static public bool wifi_event = false;
static public bool wifi_last_status = false;
static public bool network_is_read = false;
static public ManualResetEvent NetworkAvailablityBlocking = null;
NetworkChange.NetworkAvailabilityChanged += new NetworkAvailabilityChangedEventHandler(NetworkChange_NetworkAvailabilityChanged);
if (!WiFi.IsEnabled)
//WiFi.Enable(SPI.SPI_module.SPI1, (Cpu.Pin)11, (Cpu.Pin)29);// ChipworkX DevSys
WiFi.Enable(WiFi.HardwareModule.ZG100M_Compatible,SPI.SPI_module.SPI2, (Cpu.Pin)33, (Cpu.Pin)19);// EMX DevSys
//WiFi.Enable(SPI.SPI_module.SPI1, (Cpu.Pin)28, (Cpu.Pin)26);// EM DevSys
// WiFi settings
NetworkInterface[] netif = NetworkInterface.GetAllNetworkInterfaces();
Wireless80211 WiFiSettings = null;
for (int index = 0; index < netif.Length; ++index)
if (netif[index] is Wireless80211)
WiFiSettings = (Wireless80211)netif[index];
if (WiFiSettings.Ssid != "AP-SSID")
WiFiSettings.Ssid = "AP-SSID";
WiFiSettings.PassPhrase = "passphrase";
WiFiSettings.Encryption = Wireless80211.EncryptionType.WPA;
Wireless80211.SaveConfiguration(new Wireless80211[] { WiFiSettings }, false);
NetworkAvailablityBlocking = new ManualResetEvent(false);
if (!WiFi.IsLinkConnected)
Debug.Print("Waiting for WiFi link!");
NetworkAvailablityBlocking.Reset();
while (!NetworkAvailablityBlocking.WaitOne(5000, false))
Debug.Print("WiFi link is not available yet! Wrong AP settings?");
Debug.Print("Still waiting.");
break;
Debug.Print("WiFi link is ready!");
Debug.Print("Enable DHCP");
try
if (!WiFiSettings.IsDhcpEnabled)
WiFiSettings.EnableDhcp();// This function is blocking
WiFiSettings.RenewDhcpLease();// This function is blocking
network_is_read = true;
Debug.Print("Network settings:");
Debug.Print("IP Address: " + WiFiSettings.IPAddress);
Debug.Print("Subnet Mask: " + WiFiSettings.SubnetMask);
Debug.Print("Default Getway: " + WiFiSettings.GatewayAddress);
Debug.Print("DNS Server: " + WiFiSettings.DnsAddresses[0]);
catch
Debug.Print("DHCP Faild");
Debug.Print("Test DNS");
try
IPHostEntry myIP = Dns.GetHostEntry("www.ghielectronics.com");
if (myIP != null)
Debug.Print(myIP.HostName + ": " + myIP.AddressList[0].ToString());
catch
Debug.Print("Faild to Get the host entry of the FQN from DNS server!");
// This call back will be called when any change occures on Ethernet cable connection or WiFi physical link.
// Also it reports PPP connection status if PPP is enabled.
static void NetworkChange_NetworkAvailabilityChanged(object sender, NetworkAvailabilityEventArgs e)
if (e.IsAvailable)
if (WiFi.IsLinkConnected)
if (wifi_last_status != true)
wifi_last_status = true;
NetworkAvailablityBlocking.Set();
if (wifi_last_status != false)
The problem is when i use this code I get an error. I have an update version to 4.2(because I also use the STM32F4DiscoveryBoard), the error is that an overload at WiFi.Enable, this is because two pins are not assigned.
When I assigned this pins and fill in the correct SSID and password(also the encryption is good), I start the programm, there will no linked make I get only the error:
Still waiting.
Also debuggin with MFdeploy I see no other comments.
Please help
