Can anyone tell the adv\disadv between using a wifi module using a uart interface compared with using the RedSPine wifi module that uses the SPI interface.
I’m creating a board using the RedSPine Wifi module but considering changing the design to use a module like (xbee form factor)
To properly answer the question, you need to list all of your requirements. Then for each requirement, you can evaluate each alternative for performance, size and ease of development. When you do this, the answer should be obvious.
