I have designed a PCB containing an EMX board and MRF24 Wifi module. The system locks up in the function WiFi.Enable(SPI.SPI_module.SPI1, EMX.Pin.IO2, EMX.Pin.IO26); (the board is flashed to the latest firmware.) The code runs fine on my EMX development board. A second behavior is that after a hardware reset (after a WiFi.Enable call) the system hangs at startup. I assume its trying to communicate with the MRF module. I have to flash the CLR/Config again to get it startup again.
I have double checked all SPI signals, both level and timing at the MRF side and EMX side… This seems to be all ok.
I was wondering: The MRF module is delivered by Farnell. Could there be a difference in firmware in the MRF module that causes the problem?
Thanks in advance,
Rob
