When I push a button,the spider send a data to the CeruinoBee.
But the DataReceived event works only at the first time the CeruinoBee received the data.
Then the xbee DataReceived event does not raise anymore.
What I am missing?
public partial class Program
SerialPort xbee = new SerialPort("COM1", 115200);
int packet = 0;
xbee.Open();
xbee.DataReceived += new SerialDataReceivedEventHandler(xbee_DataReceived);
void xbee_DataReceived(object sender, SerialDataReceivedEventArgs e)
Debug.Print("Data Received");
try reading all data that’s available in the serial buffer at the time the event handler is entered. It might not like that you don’t do anything to the buffer…
The serial port you’re using in Gadgeteer land wires up a handler before the open() and this hits another known issue. I don’t know if there’s a way around that, short of pulling out the driver and reverting back to using the non-Gadgeteer serial port objects and handling all the setup yourself.
You are using a Gadgeteer template application so you’re using a ProgramStarted() construct not a Main(). That is why I assumed you were using the Gadgeteer XBee module capability; did you add anything to the designer for cerbuino with xbee?
No anything to the designer for cerbuino with xbee,
Why I am using the Gadgeteer template application is that I can use the on board xbee socket and other Gadgeteer module in the same time.
Now I use a timer to monitoring the received data. Its works now.
but don’t understand why the Received Event not works.
And the tutorial Architect provided is useful for me, but do not mention how to do a custom event ?
