Hi
I am quite new into NETMF (experienced C-programmer and some C# knowledge though).
I have the EMX board up and running quite fast and easy. Great!
Starting to play with the display, and this seems to work great too.
But something is missing, I think:
- I can only choose between colors black and white. Why can’t I choose other colors?
- I can’t use the “SystemMetrics.ScreenWidth” and “Height” when defining display size.
This is my source. It works, but I really want to be able to select other colors :o)
Is something missing?
I can’t add the references “Microsoft.SPOT.Presentation” and the “-.Media”, as they don’t appear in the refrences list. Is this a problem?
using System.IO;
namespace EMX_Application1
Int16 myValue = 0;
string strString;
Int16 toggle = 0;
OutputPort myLED_1 = new OutputPort((Cpu.Pin)EMX.Pin.IO48, true);
OutputPort myLED_2 = new OutputPort((Cpu.Pin)EMX.Pin.IO49, true);
Bitmap LCD = new Bitmap(320, 240);
LCD.Clear();
LCD.DrawLine(Color.White, 1, 10, 10, 310, 10);
LCD.DrawLine(Color.White, 1, 10, 10, 10, 230);
// LCD.DrawRectangle(Color.White, 1, 1, 1, 20, 20, 1, 1, Color.White, 0, 0, Color.White, 1, 1, 0);
LCD.Flush();
Thanks in advance!
Kaare
