I’ve been dipping into the published source code repositories on by Codeplex and BitBucket and the GHI module libraries seem substantially different, even when they are both titled as V4.3.
For examples, Codeplex Extender.cs looks like this
namespace Gadgeteer.Modules.GHIElectronics
// -- CHANGE FOR MICRO FRAMEWORK 4.2 --
// If you want to use Serial, SPI, or DaisyLink (which includes GTI.SoftwareI2CBus), you must do a few more steps
// since these have been moved to separate assemblies for NETMF 4.2 (to reduce the minimum memory footprint of Gadgeteer)
// 1) add a reference to the assembly (named Gadgeteer.[interfacename])
// 2) in GadgeteerHardware.xml, uncomment the lines under <Assemblies> so that end user apps using this module also add a reference.
/// <summary>
/// Represents a cable extender module which can also be used as a breakout module to interface with custom electronics, or a snooping module to monitor signals on individual pins.
/// </summary>
/// /// <example>
/// <para>The following example uses a <see cref="Extender"/> object to break out individual pins on a Gadgeteer socket.
/// This module simply provides the interfaces available on the socket (GPIO, PWM, etc).
/// </para>
/// </example>
public class Extender : GTM.Module
private Socket ExtenderSocket;
/// <summary></summary>
/// <param name="socketNumber">The mainboard socket that has the module plugged into it.</param>
public Extender(int socketNumber)
ExtenderSocket = Socket.GetSocket(socketNumber, true, this, null);
/// <summary>
/// The mainboard socket number which this Extender module is plugged into.
/// </summary>
public int ExtenderSocketNumber { get { return ExtenderSocket.SocketNumber; } }
/// <summary>
/// Returns a digital input interface associated with the specified pin on this module.
/// </summary>
/// <param name="pin">The pin to assign to the interface.</param>
/// <param name="glitchFilterMode">
/// A value from the <see cref="T:Microsoft.Gadgeteer.SocketInterfaces.GlitchFilterMode"/> enumeration that specifies
/// whether to enable the glitch filter on this interface.
/// </param>
/// <param name="resistorMode">The resistor mode for the interface port.</param>
/// <returns>The interface.</returns>
/// <exception cref="System.Exception">
/// The specified pin has already been reserved on this module.
/// </exception>
public SocketInterfaces.DigitalInput SetupDigitalInput(Socket.Pin pin, SocketInterfaces.GlitchFilterMode glitchFilterMode, SocketInterfaces.ResistorMode resistorMode)
return SocketInterfaces.DigitalInputFactory.Create(ExtenderSocket, pin, glitchFilterMode, resistorMode, this);
/// <summary>
/// Returns a digital output interface associated with the specified pin on this module.
/// </summary>
/// <param name="initialState">The initial state to place on the interface output port.</param>
/// </exception>
public SocketInterfaces.DigitalOutput SetupDigitalOutput(Socket.Pin pin, bool initialState)
return SocketInterfaces.DigitalOutputFactory.Create(ExtenderSocket, pin, initialState, this);
/// <summary>
/// Returns a digital input/output interface associated with the specified pin on this module.
/// </summary>
/// The initial state to place on the interface port;
/// this value becomes effective as soon as the port is enabled as an output port.
/// </param>
/// </param>
/// </exception>
public SocketInterfaces.DigitalIO SetupDigitalIO(Socket.Pin pin, bool initialState, SocketInterfaces.GlitchFilterMode glitchFilterMode, SocketInterfaces.ResistorMode resistorMode)
return SocketInterfaces.DigitalIOFactory.Create(ExtenderSocket, pin, initialState, glitchFilterMode, resistorMode, this);
/// <summary>
/// Returns an interrupt input interface associated with the specified pin on this module.
/// </summary>
/// </param>
/// <param name="interruptMode">The interrupt mode for the interface port.</param>
/// <returns>The interface</returns>
/// </exception>
public SocketInterfaces.InterruptInput SetupInterruptInput(Socket.Pin pin, SocketInterfaces.GlitchFilterMode glitchFilterMode, SocketInterfaces.ResistorMode resistorMode, SocketInterfaces.InterruptMode interruptMode)
return SocketInterfaces.InterruptInputFactory.Create(ExtenderSocket, pin, glitchFilterMode, resistorMode, interruptMode, this);
/// <summary>
/// Returns an analog input interface associated with the specified pin on this module.
/// </summary>
public SocketInterfaces.AnalogInput SetupAnalogInput(Socket.Pin pin)
return SocketInterfaces.AnalogInputFactory.Create(ExtenderSocket, pin, this);
// TODO: Determine whether AnalogOutput should be added to Gadgeteer.SocketInterfaces
/// <summary>
/// Returns an analog output interface associated with the specified pin on this module.
/// </summary>
public SocketInterfaces.AnalogOutput SetupAnalogOutput(Socket.Pin pin)
return SocketInterfaces.AnalogOutputFactory.Create(ExtenderSocket, pin, this);
/// <summary>
/// Returns an pulse width modulation (PWM) output interface associated with the specified pin on this module.
/// </summary>
/// <param name="pin">The pin to use for the PWM interface.</param>
/// <returns>The PWM interface.</returns>
public SocketInterfaces.PwmOutput SetupPWMOutput(Socket.Pin pin)
return SocketInterfaces.PwmOutputFactory.Create(ExtenderSocket, pin, false, this);
I know it says // – CHANGE FOR MICRO FRAMEWORK 4.2 – at the top but it’s from the 4.3 source.
However, BitBucket looks like this:
using GTI = Gadgeteer.SocketInterfaces;
/// <summary>
/// An Extender module for Microsoft .NET Gadgeteer.
/// </summary>
private Socket socketA;
private Socket socketB;
/// <summary>Constructs a new instance.</summary>
this.socketA = Socket.GetSocket(socketNumber, true, this, null);
this.socketB = Socket.SocketInterfaces.CreateUnnumberedSocket(socketNumber.ToString() + "-" + " Extender");
this.socketB.SupportedTypes = this.socketA.SupportedTypes;
for (int i = 3; i < 10; i++)
this.socketB.CpuPins[i] = this.socketA.CpuPins[i];
this.socketB.SerialPortName = this.socketA.SerialPortName;
this.socketB.SPIModule = this.socketA.SPIModule;
this.socketB.AnalogOutput5 = this.socketA.AnalogOutput5;
this.socketB.AnalogInput3 = this.socketA.AnalogInput3;
this.socketB.AnalogInput4 = this.socketA.AnalogInput4;
this.socketB.AnalogInput5 = this.socketA.AnalogInput5;
this.socketB.PWM7 = this.socketA.PWM7;
this.socketB.PWM8 = this.socketA.PWM8;
this.socketB.PWM9 = this.socketA.PWM9;
this.socketB.AnalogInputIndirector = this.socketA.AnalogInputIndirector;
this.socketB.AnalogOutputIndirector = this.socketA.AnalogOutputIndirector;
this.socketB.DigitalInputIndirector = this.socketA.DigitalInputIndirector;
this.socketB.DigitalIOIndirector = this.socketA.DigitalIOIndirector;
this.socketB.DigitalOutputIndirector = this.socketA.DigitalOutputIndirector;
this.socketB.I2CBusIndirector = this.socketA.I2CBusIndirector;
this.socketB.InterruptIndirector = this.socketA.InterruptIndirector;
this.socketB.PwmOutputIndirector = this.socketA.PwmOutputIndirector;
this.socketB.SpiIndirector = this.socketA.SpiIndirector;
this.socketB.SerialIndirector = this.socketA.SerialIndirector;
Socket.SocketInterfaces.RegisterSocket(this.socketB);
/// <summary>
/// Returns the socket number for socket on the module.
/// </summary>
public int ExtenderSocketB { get { return this.socketB.SocketNumber; } }
/// <summary>
/// Creates a digital input on the given pin.
/// </summary>
/// <param name="pin">The pin to create the interface on.</param>
/// <param name="glitchFilterMode">The glitch filter mode for the interface.</param>
/// <param name="resistorMode">The resistor mode for the interface.</param>
/// <returns>The new interface.</returns>
public GTI.DigitalInput CreateDigitalInput(Socket.Pin pin, GTI.GlitchFilterMode glitchFilterMode, GTI.ResistorMode resistorMode)
return GTI.DigitalInputFactory.Create(this.socketB, pin, glitchFilterMode, resistorMode, this);
/// <summary>
/// Creates a digital output on the given pin.
/// </summary>
/// <param name="initialState">The initial state for the interface.</param>
public GTI.DigitalOutput CreateDigitalOutput(Socket.Pin pin, bool initialState)
return GTI.DigitalOutputFactory.Create(this.socketB, pin, initialState, this);
/// <summary>
/// Creates a digital input/output on the given pin.
/// </summary>
public GTI.DigitalIO CreateDigitalIO(Socket.Pin pin, bool initialState, GTI.GlitchFilterMode glitchFilterMode, GTI.ResistorMode resistorMode)
return GTI.DigitalIOFactory.Create(this.socketB, pin, initialState, glitchFilterMode, resistorMode, this);
/// <summary>
/// Creates an interrupt input on the given pin.
/// </summary>
/// <param name="interruptMode">The interrupt mode for the interface.</param>
public GTI.InterruptInput CreateInterruptInput(Socket.Pin pin, GTI.GlitchFilterMode glitchFilterMode, GTI.ResistorMode resistorMode, GTI.InterruptMode interruptMode)
return GTI.InterruptInputFactory.Create(this.socketB, pin, glitchFilterMode, resistorMode, interruptMode, this);
/// <summary>
/// Creates an analog input on the given pin.
/// </summary>
public GTI.AnalogInput CreateAnalogInput(Socket.Pin pin)
return GTI.AnalogInputFactory.Create(this.socketB, pin, this);
/// <summary>
/// Creates an analog output on the given pin.
/// </summary>
public GTI.AnalogOutput CreateAnalogOutput(Socket.Pin pin)
return GTI.AnalogOutputFactory.Create(this.socketB, pin, this);
/// <summary>
/// Creates a pwm output on the given pin.
/// </summary>
public GTI.PwmOutput CreatePwmOutput(Socket.Pin pin)
return GTI.PwmOutputFactory.Create(this.socketB, pin, false, this);
Now, the latest SDK contains the methods seen in the BitBucket source, so is the Codeplex completely out of date now and should I just use the BitBucket source for everything?
