Last night I stumbled across a youtube video of Gus demoing a robot arm controlled by a joystick and a CanXtra, but now I can’t find the link! I also can’t find any mention of the project in the Wiki or elsewhere. Anybody know where it might be hiding? archived maybe?
This is from long years a go! It uses a Serial servo controller. Here is the code but note it is too old and outdated probably.
* Robot Arm reference: http://www.lynxmotion.com/images/howto/ssc-168.pdf
// This is if LCD is connected (used in CANxtra example)
// For USBizi, you should remove this define and also remove the graphics assemblies (Microsoft.SPOT.Graphics, Microsoft.SPOT.TinyCore)
//#define USE_DISPLAY
using System.Collections;
using System.IO.Ports;
//using Microsoft.SPOT.Input;
//using Microsoft.SPOT.Presentation;
//using Microsoft.SPOT.Presentation.Media;
///using Microsoft.SPOT.Presentation.Controls;
//using Microsoft.SPOT.Presentation.Shapes;
using System.Text;
using System.IO;
//using GHIElectronics.System;
//using GHIElectronics.System.SystemDevices;
//using GHIElectronics.System.IO;
//using GHIElectronics.Hardware;
using GHIElectronics.NETMF.USBHost;
namespace LynxmotionRobotArm
public static USBH_Joystick joy;
#if USE_DISPLAY
static Bitmap screen = new Bitmap(SystemMetrics.ScreenWidth, SystemMetrics.ScreenHeight);
static Font smallFont = Resources.GetFont(Resources.FontResources.small);
#else
static class screen
public static void Clear() { }
public static void Flush() { }
#endif
static SerialPort port;
class Servo
public int id;
public int position = 1500;
public int state = 0; // 0: none
// 1: increasing
// -1: decreasing
public Servo(int id)
this.id = id;
public void Increase() { state = 1; }
public void Decrease() { state = -1; }
public void Stop() { state = 0; }
public void Process()
switch (state)
case 1: // increasing
if (position < 1740)
position += 10;
//SetArmPosition(id, position);
break;
case -1: // decreasing
if (position > 1115)
position -= 10;
break;
const int X_SERVO = 0;
const int Y_SERVO = 1;
const int ARM_UP_DOWN_SERVO = 2;
const int MOUTH_UP_DOWN_SERVO = 3;
const int MOUTH_CATCH_SERVO = 4;
const int MOUTH_ROTATE_SERVO = 5;
static Servo[] servos = new Servo[6]{
new Servo(X_SERVO),
new Servo(Y_SERVO),
new Servo(ARM_UP_DOWN_SERVO),
new Servo(MOUTH_UP_DOWN_SERVO),
new Servo(MOUTH_CATCH_SERVO),
new Servo(MOUTH_ROTATE_SERVO),
try
screen.Clear();
print("Starting...", 0, 0);
screen.Flush();
port = new SerialPort("COM1", 115200, Parity.None, 8, StopBits.One);
port.ReadTimeout = 5000;
port.WriteTimeout = 5000;
port.Open();
SetArmPosition(0, 1500);
SetArmPosition(1, 1500);
SetArmPosition(2, 1500);
SetArmPosition(3, 1500);
SetArmPosition(4, 1500);
SetArmPosition(5, 1500);
USBHostController.DeviceConnectedEvent += new USBH_DeviceConnectionEventHandler(USBHostController_DeviceConnectedEvent);
foreach (Servo s in servos)
s.Process();
/*if (joy != null)
screen.Clear();
print("(x,y) = (" + joy.Cursor.X.ToString() + "," + joy.Cursor.Y.ToString() + ")", 0, 0);
print("Elbow Pos: " + servos[ARM_UP_DOWN_SERVO].position.ToString(), 0, 10);
print("Wrist Pos: " + servos[MOUTH_UP_DOWN_SERVO].position.ToString(), 0, 20);
print("Wrist Rot: " + servos[MOUTH_ROTATE_SERVO].position.ToString(), 0, 30);
print("Gripper: " + servos[MOUTH_CATCH_SERVO].position.ToString(), 0, 40);
screen.Flush();
Thread.Sleep(10);
catch (Exception e)
screen.Clear();
print("EXP: " + e.Message, 0, 0);
screen.Flush();
static void USBHostController_DeviceConnectedEvent(USBH_Device device)
screen.Clear();
print("Joystick connected", 0, 0);
screen.Flush();
joy = new USBH_Joystick(device);
//joy.Disconnected += Disconnected;
joy.SetCursorBounds(1000, 2000, 1000, 2000);
joy.JoystickXYMove += Moved;
joy.JoystickButtonDown += ButtonDown;
joy.JoystickButtonUp += ButtonUp;
/*static void Disconnected(Joystick joy, JoystickEventArgs args)
screen.Clear();
print("Joystick Disconnected", 0, 0);
screen.Flush();
static void Moved(USBH_Joystick joy, USBH_JoystickEventArgs args)
//SetArmPosition(0, joy.Cursor.X);
//SetArmPosition(1, joy.Cursor.Y);
if (joy.Cursor.X > 1600)
servos[X_SERVO].Increase();
else if (joy.Cursor.X < 1400)
servos[X_SERVO].Decrease();
servos[X_SERVO].Stop();
if (joy.Cursor.Y > 1600)
servos[Y_SERVO].Increase();
else if (joy.Cursor.Y < 1400)
servos[Y_SERVO].Decrease();
servos[Y_SERVO].Stop();
static void SetArmPosition(int servo, int pos)
byte[] cmd = Encoding.UTF8.GetBytes("#" + servo.ToString() + "P" + pos.ToString() + "T150\r");
port.Write(cmd, 0, cmd.Length);
static void ButtonDown(USBH_Joystick joy, USBH_JoystickEventArgs args)
switch (args.ChangedButton)
case 5: // arm down
servos[ARM_UP_DOWN_SERVO].Increase();
break;
case 6: // arm up
servos[ARM_UP_DOWN_SERVO].Decrease();
break;
case 3: // mouthRotate CCW
servos[MOUTH_ROTATE_SERVO].Increase();
break;
case 4: // mouthRotate CW
servos[MOUTH_ROTATE_SERVO].Decrease();
break;
case 2: // mouth up
servos[MOUTH_UP_DOWN_SERVO].Increase();
break;
case 1: // mouth down
servos[MOUTH_UP_DOWN_SERVO].Decrease();
break;
case 0:
servos[MOUTH_CATCH_SERVO].Decrease();
break;
static void ButtonUp(USBH_Joystick joy, USBH_JoystickEventArgs args)
case 5: // arm down
servos[ARM_UP_DOWN_SERVO].Stop();
break;
case 6: // arm up
break;
servos[MOUTH_ROTATE_SERVO].Stop();
break;
break;
case 2: // mouth up
servos[MOUTH_UP_DOWN_SERVO].Stop();
break;
break;
case 0:
servos[MOUTH_CATCH_SERVO].Increase();
break;
// LCD Print
public static void print(string str, int x, int y)
#if USE_DISPLAY
screen.DrawText(str, smallFont, Color.White, x, y);
#else
Debug.Print(str);
#endif
too old? Never!
Thx
Ransom…
Any progress on Spider Web?
No. I asked for 2 quotes and neither has responded. I’ve even reminded both… not sure why I’m getting the silent treatment.
That servo example works fine.
I used it for my hexapod (servo code).
