I remember seeing in a video they mentioned that offsets and possibly other hardware would show up in the catalog. And I just ordered a couple Tamiya boards. /sigh
@ devhammer I chuckled when I first read that but then I started to wonder why couldn’t there be a logo type box building kit and the more I thought about the clearer it was, that was a freaking brilliant idea. The modules are standardized so blocks could be built that mount modules with their front edge flush with the outside edge of the block and the area between the mounting pegs open to allow access to the card reader, music jacks, power plugs, etc. Modules like Joysticks, buttons, Potentiometer, etc could all share the same surface mount block that have a hole in the middle allowing cables etc to be connected to internally mounted project boards. So you wouldn’t have to make unique blocks for each module, so making a Lego case kit would be highly doable. You could make the top plate like an open grid that these button blocks plug into and where you don’t need a button block you could snap on a cap. Lego blocks for cases is a very cool idea.
The only downside is I’d have to get another purple and pink case to match my existing module case
It’s a very cool idea. Unfortunately the creators have chosen to mar the project with a name worthy of a snickering teenage boy (and not a particularly mature one, at that), completely unsuitable for children. The author(s), alas, seem more interested in provocation than in truly making useful stuff.
Shouldn’t be difficult. AFAIK the Mindstorms sensors use normal GPIO, PWM, and analog inputs and outputs. The only hard part is the physical interface (and that’s just RJ-45 on the new versions, IIRC).
@ HughB I’ve been playing a little bit with doing a Mindstorms motor controller module, but haven’t gotten all that far yet. Looks like it’s just basic PWM, so should be pretty simple to implement that part. Reading the encoder is a little more involved, depending on how many motors one would want to control from a single module.
@ godefroi
Note that the mindsensors connector is NOT a standard RJ-45. The tab is offset, and while you can make your own by modifying an existing RJ-45, it’s probably less hassle in the long run to get the real deal.
I picked up one of these to do some prototyping:
You can also get connectors from mindsensors as well:
