In-Field Update?
Deploy?
In-Field Update?
Deploy?
It is best to test as I am not 10% sire but I think IFU will not touch EWR.
Ok, I will try it.
Max size?
I run at the moment at about 10k, is it to much?
That’s not a lot of confidence… ![]()
I never typed 10%!! Where did that come from! Crazy spell check!
I hope you are a 100% sire.
max size of what?
what are the 10k? app size? data to store in ewr size?
which mainboard?
for the app:
for ifu you need to have the app already installed on one device to get the source files for your ifufor ewr:
if depends on which mainboard you use, use mfdeploy or the new ghi tool to get your ewr size (i assume you don’t have a prob with 10k)
10k its for log data, but after reading a bit I see that I should be storing it on SD instead.
G120
I also need to store serial number, but EWR seams to “weak” for this.
I saw PermanentUserKey a time ago but cant find it in 4.2.10.0 ???
There was a “man” that got pregnant …
What I mean by “weak” is that it feels like the EWR is unstable after reading topics about it.
If I set a serial number I must be 100% sire
that it doesn’t drop it…
@ Honken - Today I used the (beta) GHI Firmware Updater Tool to update my G120 firmware from 4.2.10.0 to 4.2.10.1, and also, just for fun, decided to use IFU to update the firmware. In both cases, my EWR data was maintained.
@ Iggmoe - Thanks alot for testing this!
