Hello,
I want to use a Cerbuino Net. It seems to have some problems with DHCP. In the forum I found an article that I have to use
EthernetENC28J60 Eth1 = new EthernetENC28J60(SPI.SPI_module.SPI1, GHI.Pins.Generic.GetPin(‘A’, 13), GHI.Pins.Generic.GetPin(‘A’, 14), GHI.Pins.Generic.GetPin(‘B’, 10));
But what is the referece for SPI.SPI_module.SPI1? I work with .NET 4.3
@ User_8034 - It just means the first SPI channel on the device. NETMF uses the SPI channel to figure out which SPI pins to use since a device can have multiple sets of SPI pins.
Thanks, and in which namespace do I find this?
@ User_8034 - Microsoft.SPOT.Hardware
Are you shure? In .Net 4.3 I only find Systeminfo and Utility.
@ User_8034 - You need to add a reference to Microsoft.SPOT.Hardware.dll
