I’m quite curious to hear more about PowerMate. It sounds like a very usefull tool if I inderstand the short desciption on the outrageouscircuits website correctly. Wish someone will tell is more about it and when it will become available.
Ok. I’m willing to pay a little extra for open source What would really be cool would be a serial output for logging data coming out of it. Can that be done via the programming plug? Perhaps add some RX/TX pins to the next model and have it constantly stream the values?
How much longer till this is available? I’m holding off on ordering my RETRO until I can ship this at the same time.
this snippet may help… i stripped it down from some very early test program, it uses the programming port. I was using TeraTerm on the pc side. As-is, it may not compile
#include "mbed.h"
#include "USBSerial.h"
int main(void) {
uint8_t buf[128];
USBSerial serial((uint16_t)0x1B9F , (uint16_t)0x0104, (uint16_t)0x0001, false); // ghi bootloader VID/DIV
while(1)
serial.printf("Press X to for line echoing\r\n");
buf[0] = serial._getc();
// Command Processing
if ('X' == buf[0]) {
serial.printf("saw X\r");
while(0xd != (buf[0] = serial._getc()) ) {
serial.putc(buf[0]);
wait(0.01);
serial.putc(0xa);
wait(.50);
USBSerial may be fine. I’m just wondering if there’s any way to do automated logging over time. If its to a PC, then that would be acceptable. However, having UART access does open up some other options.
Tried to ask a couple of Qs on the mbed forum but was denied (not published yet). Anyhoo…
What kind of accuracy and precision can we expect from this? How much power does it draw from USB? Is it’s own power draw factored into the displayed data?
