Hi
Im really new to anything related to hardware but i have identified that i need the following for my project:
3 Motor Driver L298 Module p
1 USB Client DP Module D
1 Gyro Module I
2 Pulse Count Y
1 SD Card Module F
1 Display TE35 Module B R G T
1 (USB Host Module) H
1 WiFi RS21 Module S
What board (prefer Gadgeteer)should i choose for my project…?
Raptor has more memory and more power (it is based on G400)
Spider2 is only based on G120.
If you have a very intensive graphics display in mind, people suggest the G400. If you have a medium intensity app and graphics requirements then G120 is very capable.
Concur with Brett. Having used both the G120 and the G400 with LCD displays I would say use the G120 if your display consists of a few buttons and text for updating values etc. If you want lots of graphics and text and loads of buttons etc, choose the G400 for a smoother experience. The difference is very noticeable.
Thanks alot for the replies. They have helped alot.
Short info regarding display i need some buttons an tekst, but I do not need the display to update while the mekanics is running.
L298 uses 2x PWM pins and 2x direction pins. So if you have 3x modules, you need 6x PWM pins and 6x direction pins. You can do that with 2x P sockets and a few pins, so you need a breadboard and some Extender /Breakout Modules and some jumper wires… and some driver changes.
Hub AP5 is probably fine, yes (I don’t own one so can’t say I’ve done it - but it’s perfect on paper)
but if you buy anything else, add some extender or breakout modules (and gadgeteer cables) and get a breadboard ($3 on ebay). You’ve started down the rabbit hole, you need atleast* this much. Oh and some jumper wires. Oh and some… But no, really, you want jumper wires
