@ Tempered, Can you be more specific than “crash”. Is there an error message or does the program just stop working? Can you post the code that interprets the PS/2 input?
The below is the code. The connect event fires. It also links the events to the object instance… Just no events ever fire. Before i removed the USBHost object on the designer i was getting USB Device not supported.
public partial class Program
USBH_Keyboard KeyB = null;
//Ascended.Helpers.UsbDiscoveryHelper Helper = new Ascended.Helpers.UsbDiscoveryHelper();
char_Display.PrintString("Hello");
//USBHostController.DeviceConnectedEvent += USBHostController_DeviceConnectedEvent;
void USBHostController_DeviceConnectedEvent(USBH_Device device)
if (device.TYPE == USBH_DeviceType.Keyboard)
KeyB = new USBH_Keyboard(device);
KeyB.CharDown += KeyB_CharDown; //these commands DO execute
KeyB.CharUp += KeyB_CharUp;
KeyB.Disconnected += KeyB_Disconnected;
KeyB.KeyDown += new USBH_KeyboardEventHandler(KeyB_KeyDown);
KeyB.KeyUp += KeyB_KeyUp;
}//catch
void KeyB_Disconnected(USBH_Keyboard sender, USBH_KeyboardEventArgs args)
throw new NotImplementedException(); //NEVER EXECUTES
void KeyB_CharUp(USBH_Keyboard sender, USBH_KeyboardEventArgs args)
throw new NotImplementedException();//NEVER EXECUTES
void KeyB_CharDown(USBH_Keyboard sender, USBH_KeyboardEventArgs args)
void KeyB_KeyDown(USBH_Keyboard sender, USBH_KeyboardEventArgs args)
void KeyB_KeyUp(USBH_Keyboard sender, USBH_KeyboardEventArgs args)
Debug.Print(args.Key.ToString());//NEVER EXECUTES
