I face a strange behavior to me. I want to grab datas from a webpage on the net.
I use a cobra I but with the webclient gadgeteer library.
The thing is that I can grab my datas correctly one time, but all other try return no response at all…
I really don’t know why. What am I doing wrong ?
My first thought was to think that using the gadgeteer lib was not a good idea with plain netmf, but it works one time ! so…
Any idea ?
Thank you in advance
using System.IO;
using System.Net;
using System.Text;
using System.Collections;
using Microsoft.SPOT.Net;
using Microsoft.SPOT.Input;
using Microsoft.SPOT.Touch;
using GHI.Networking;
using GHI.Pins;
using GHI.Glide;
using GHI.Glide.Display;
using GHI.Glide.UI;
using GHI.IO;
using GHI.Utilities;
using Gadgeteer;
using Gadgeteer.Networking;
namespace NETMF_4._3_webClient_timer
#region variables
static readonly EthernetBuiltIn eth0 = new EthernetBuiltIn();
const string ipAdress = "192.168.1.222";
const string subnetMask = "255.255.255.0";
const string gatewayAdress = "192.168.1.254";
static string[] dns = { "192.168.1.254" };
const string url = "http://www.greg-photo.net/essai.php?id=123456";
#endregion
Debug.Print("Initialising Network...");
eth0.Open();
eth0.EnableStaticIP(ipAdress, subnetMask, gatewayAdress);
eth0.EnableStaticDns(dns);
NetworkChange.NetworkAddressChanged += NetworkChange_NetworkAddressChanged;
NetworkChange.NetworkAvailabilityChanged += NetworkChange_NetworkAvailabilityChanged;
while (eth0.NetworkInterface.IPAddress == "0.0.0.0")
Debug.Print("Waiting for DHCP");
Thread.Sleep(250);
TimerCallback timercallback = null;
timercallback = new TimerCallback(sendRequest);
System.Threading.Timer grab = new System.Threading.Timer(timercallback,null,10000,20000);
static void NetworkChange_NetworkAvailabilityChanged(object sender, NetworkAvailabilityEventArgs e)
Debug.Print("Network available: " + e.IsAvailable.ToString());
static void NetworkChange_NetworkAddressChanged(object sender, EventArgs e)
Debug.Print("Network Adress Changed");
Debug.Print("DHCP : " + eth0.IsDhcpEnabled.ToString());
Debug.Print("IP : " + eth0.NetworkInterface.IPAddress);
Debug.Print("SN : " + eth0.NetworkInterface.SubnetMask);
Debug.Print("GW : " + eth0.NetworkInterface.GatewayAddress);
//Debug.Print("DNS : " + ethernetJ11D.NetworkInterface.DnsAddresses.GetValue(0);
foreach (string dnsitem in eth0.NetworkInterface.DnsAddresses)
Debug.Print("DNS : " + dnsitem);
public static void sendRequest(object o)
//Send the request gadgeteer
Gadgeteer.Networking.HttpRequest request = WebClient.GetFromWeb(url);
request.ResponseReceived += request_ResponseReceived;
Thread.Sleep(1000);
Debug.Print("Sending Request...");
Debug.Print(request.URL);
request.SendRequest();
public static void request_ResponseReceived(HttpRequest sender, HttpResponse response)
Debug.Print("response request_ResponseReceived...");
if (response.StatusCode == "200")
Debug.Print("Response code : " + response.StatusCode);
Debug.Print("url : " + response.URL);
Debug.Print("Server : " + response.ContentType);
Debug.Print("Response : "+response.Text);
Debug.Print("Problem HTTP-Response: " + response.StatusCode);
[line]
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managé) : ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.WebClient.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managé) : ‘C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Hardware.dll’ chargé
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managé) : ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Xml.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managé) : ‘C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Glide.dll’ chargé
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managé) : ‘C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Networking.dll’ chargé
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managé) : ‘G:\Cours\STI2D\SIN\C#\Projects\FEZ Cobra\4.3\NETMF-4.3-webClient-timer\NETMF-4.3-webClient-timer\bin\Debug\le\NETMF-4.3-webClient-timer.exe’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managé) : ‘C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Pins.dll’ chargé
Le thread ‘’ (0x2) s’est arrêté avec le code 0 (0x0).
Initialising Network…
Network available: True
DHCP : False
IP : 192.168.1.222
SN : 255.255.255.0
GW : 192.168.1.254
DNS : 192.168.1.254
response request_ResponseReceived…
Response code : 200
url : http://www.greg-photo.net/essai.php?id=123456
Server : text/html; charset=UTF-8
Response : OK
Le thread ‘’ (0x5) s’est arrêté avec le code 0 (0x0).
Sending Request…
Le thread ‘’ (0x6) s’est arrêté avec le code 0 (0x0).
Sending Request…
Le thread ‘’ (0x7) s’est arrêté avec le code 0 (0x0).
Sending Request…
Le programme ‘[26] Micro Framework application: Managé’ s’est arrêté avec le code 0 (0x0).
