i connect a Webcam to my Panda II Board successfully.
Now, i would like to Start the Stream from the camera to only Analyse the data and here i went into trouble. I cant understand the USB Video Class to make this happen. My brain is totaly useless for that
Have anyone a hint for me what to send via setuptransfer ?
Alright thank you for the info.
You might want to add this info to the news thread also.
In the news thread there is stated that it would have been released last week.
I guess you will not tell us this new feature? :whistle:
this relax me a little bit
I saw so many interfaces and descriptors in the uvc, no chance for me to solve this.
i tried it a long time, but for now i will wait for your solution.
great work, thanks !
Any progress with this for the Panda-II? The recent contest announcement reminded me of a project idea I’ve had for a while… I need to take maybe 10 frames/sec and analyze the colors at only a few spots. I don’t need to play the video back. I’d rather not have to upgrade to a Chipworx/EMX to make this work. Any and all ideas appreciated.
Is there an example of this documented somewhere? I don’t see anything on this site. Camera would be just fine. I really only need to examine data from still photos anyway. Is there a recommended camera for the Panda-II?
Maybe you could hook up with a camera and let the camera take the pictures and then transfer and process the pictures from mass storage mode. It will require a camera that can be remote controlled and you’ll have to process directly on the stream because of memory constraints.
You could also use a camera with image processing capabilities and just transfer the results. Kinect is such a type of camera.
There are serial cameras that might fit the bill, but ultimately memory is the issue as everyone has pointed out. You could do tricky stuff like buffering small chunks to SD card or external storage, and I am sure you could get it to work but would it meet your goals, who knows.
