G’day,
Has anyone had issues with the Watchdog as per the Wiki Tutorial and the Spider?
My board just keeps rebooting when using the watchdog so as a good developer, I must be the problem! Is the following code actually incorrect?
Even if I move the Watchdog into the main() function in the partial class, I still end up with a rebooting device.
Create new gadgeteer project
Add LCD and MultiColor led to Socket 4
Add this code to the partial class:
GHIElectronics.NETMF.Hardware.LowLevel.Watchdog.Enable(5000);
display.SimpleGraphics.DisplayText("Running", Resources.GetFont(Resources.FontResources.NinaB), Color.White,
0, 0);
private static bool beRed = false;
static Thread WDTCounterReset;
static void WDTCounterResetLoop()
Thread.Sleep(3000);
if (beRed)
led.TurnRed();
beRed = false;
led.TurnBlue();
beRed = true;
GHIElectronics.NETMF.Hardware.LowLevel.Watchdog.ResetCounter();
Compile
Deploy
Run
Watch device boot, say running and then reboot
