Want to use Panda II with more than 8 servos
I want to use Panda II with more than 8 servos, after I search around and found this:
in the Servo Motor on the Wiki page.
What is the shield that this link refered to:
http://www.tinyclr.com/hardware/1/fez-domino/#/grid/item/16/
in the new catalog??
Thanks,
http://www.ghielectronics.com/catalog/product/166
Thanks sıɹɥɔ!
You don’t need that product either. You can connect as much servos as you need using output compare feature.
Joe,
Great! Thanks.
By the way, Do you know if this project is on the Wiki or on the Code page??
This drive uses OC to contorl the servo.
[url]http://code.tinyclr.com/project/46/servo-motor/[/url]
