Not sure where to start, but as usual getting this stuff to work is an absolute nightmare. I have VS 2013 / Fez Spider installed and have also tried to make sense of this post https://www.ghielectronics.com/community/forum/topic?id=17369 as all the links are bad. OK, so Google it is. I installed what was described in the above link. I can create a Gadgeteer sln in VS 2013, but of course I cannot deploy it. Sorry for the tone, but this is so unbelievable frustrating.
Here is what I get when I F5 from vs 2013. Note when I specified the mother board, I chose 4.3.
Found debugger!
Create TS.
Loading start at a0e00000, end a0e2f494
Assembly: mscorlib (4.3.1.0) Assembly: Microsoft.SPOT.Native (4.3.1.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.3
.1.0) Assembly: System.Security (4.3.1.0) Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0) Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0) Assembly: System.IO (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0) Assembly: Microsoft.SPOT.Touch (4.3.1.0)
Assembly: Microsoft.SPOT.Ink (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Attaching deployed file.
Assembly: Gadgeteer (2.43.1.0) Attaching deployed file.
Assembly: GHI.Hardware (4.3.6.0) ***********************************************************************
ERROR!!! Firmware version does not match managed code version!!! *
Invalid native checksum: GHI.Hardware 0xEB638545!=0x59043403 *
Assembly: GadgeteerApp4 (1.0.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.USBClientDP (4.3.6.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.3.1.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZSpider (4.3.6.0) Resolving.
Assembly: GadgeteerApp4 (1.0.0.0) needs assembly ‘GTM.GHIElectronics.Button’ (4.3.6.0)
Assembly: GadgeteerApp4 (1.0.0.0) needs assembly ‘GHIElectronics.Gadgeteer.FEZSpider’ (4.3.6.0)
Assembly: GHIElectronics.Gadgeteer.FEZSpider (4.3.6.0) needs assembly ‘GHI.Hardware’ (4.3.6.0)
Assembly: GHIElectronics.Gadgeteer.FEZSpider (4.3.6.0) needs assembly ‘GHI.Usb’ (4.3.6.0)
Error: a3000000
Waiting for debug commands…
The program ‘[2] Micro Framework application: Managed’ has exited with code 0 (0x0).
From MFDeploy:Ping I get Pinging… TinyCLR
From MFDeploy:Plug-In:Debug:Show Device Info I get:
Pinging… TinyCLR
DeviceInfo:
HAL build info: 4.3.1.0, Microsoft Copyright (C) Microsoft Corporation. All rig
OEM Product codes (vendor, model, SKU): 255, 0, 65535
Serial Numbers (module, system):
FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Solution Build Info: 4.3.4.0, Copyright (C) GHI Electronics, LLC
AppDomains:
default, id=1
Assemblies:
mscorlib,4.3.1.0
Microsoft.SPOT.Native,4.3.1.0
Microsoft.SPOT.Security.PKCS11,4.3.1.0
System.Security,4.3.1.0
Microsoft.SPOT.Hardware,4.3.1.0
Microsoft.SPOT.Graphics,4.3.1.0
Microsoft.SPOT.TinyCore,4.3.1.0
Microsoft.SPOT.IO,4.3.1.0
System.IO,4.3.1.0
Microsoft.SPOT.Hardware.Usb,4.3.1.0
Microsoft.SPOT.Hardware.SerialPort,4.3.1.0
Microsoft.SPOT.Touch,4.3.1.0
Microsoft.SPOT.Ink,4.3.1.0
Microsoft.SPOT.Hardware.PWM,4.3.1.0
Gadgeteer,2.43.1.0
GadgeteerApp4,1.0.0.0
GTM.GHIElectronics.USBClientDP,4.3.6.0
Microsoft.SPOT.Net,4.3.1.0
GHIElectronics.Gadgeteer.FEZSpider,4.3.6.0
- Do I need to uninstall everything yet again or what do I do???
- Update the firmware???
thanks in advance
