hmm… yes, it seems the default framework when creating is always 4.2… but how i change that? cuz instructions say, I should have ONLY installed 4.3 cuz it can’t coexist with other SDKs.
When I crate now a standart project and load it on the Hydra i get 3 errors… (but they are too fast away as that I could copy em >.<
I still see a loooot of 4.2 in the output… is that normal?
Console output is:
Create TS.
Loading start at 20251460, end 20286794
Assembly: mscorlib (4.3.1.0) Assembly: Microsoft.SPOT.Native (4.3.1.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.3
.1.0) Assembly: System.Security (4.3.1.0) Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0) Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0) Assembly: System.IO (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0) Assembly: Microsoft.SPOT.Touch (4.3.1.0)
Assembly: Microsoft.SPOT.Ink (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.OneWire (4.3.1.0) Assembly: System.Xml (4.3.1.0)
Assembly: Microsoft.SPOT.Time (4.3.1.0) Assembly: Microsoft.SPOT.Net (4.3.1.0)
Assembly: System (4.3.1.0) Assembly: Microsoft.SPOT.Net.Security (4.3.1.0)
Assembly: System.Net.Security (4.3.1.0) Loading Deployment Assemblies.
Attaching deployed file.
Assembly: GHI.OSHW.Hardware (4.2.6.1) Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0) Attaching deployed file.
Assembly: Microsoft.VisualBasic (1.0.0.0) Attaching deployed file.
Assembly: GadgeteerApp4 (1.0.0.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZHydra (4.2.109.0) Resolving.
Assembly: GHI.OSHW.Hardware (4.2.6.1) needs assembly ‘mscorlib’ (4.2.0.0)
Assembly: GHI.OSHW.Hardware (4.2.6.1) needs assembly ‘Microsoft.SPOT.Hardware’ (4.2.0.0)
Assembly: GHI.OSHW.Hardware (4.2.6.1) needs assembly ‘Microsoft.SPOT.Native’ (4.2.0.0)
Assembly: Gadgeteer (2.42.0.0) needs assembly ‘mscorlib’ (4.2.0.0)
Assembly: Gadgeteer (2.42.0.0) needs assembly ‘Microsoft.SPOT.Hardware’ (4.2.0.0)
Assembly: Gadgeteer (2.42.0.0) needs assembly ‘Microsoft.SPOT.Hardware.PWM’ (4.2.0.1)
Assembly: Gadgeteer (2.42.0.0) needs assembly ‘Microsoft.SPOT.TinyCore’ (4.2.0.0)
Assembly: Gadgeteer (2.42.0.0) needs assembly ‘Microsoft.SPOT.Graphics’ (4.2.0.0)
Assembly: Gadgeteer (2.42.0.0) needs assembly ‘Microsoft.SPOT.Net’ (4.2.0.0)
Assembly: Gadgeteer (2.42.0.0) needs assembly ‘Microsoft.SPOT.Native’ (4.2.0.0)
Assembly: Gadgeteer (2.42.0.0) needs assembly ‘Microsoft.SPOT.IO’ (4.2.0.0)
Assembly: Gadgeteer (2.42.0.0) needs assembly ‘System.IO’ (4.2.0.0)
Assembly: GadgeteerApp4 (1.0.0.0) needs assembly ‘Gadgeteer’ (2.42.0.0)
Assembly: GadgeteerApp4 (1.0.0.0) needs assembly ‘GHIElectronics.Gadgeteer.FEZHydra’ (4.2.109.0)
Assembly: GHIElectronics.Gadgeteer.FEZHydra (4.2.109.0) needs assembly ‘Gadgeteer’ (2.42.0.0)
Assembly: GHIElectronics.Gadgeteer.FEZHydra (4.2.109.0) needs assembly ‘mscorlib’ (4.2.0.0)
Assembly: GHIElectronics.Gadgeteer.FEZHydra (4.2.109.0) needs assembly ‘Microsoft.SPOT.Hardware’ (4.2.0.0)
Assembly: GHIElectronics.Gadgeteer.FEZHydra (4.2.109.0) needs assembly ‘GHI.OSHW.Hardware’ (4.2.6.1)
Assembly: GHIElectronics.Gadgeteer.FEZHydra (4.2.109.0) needs assembly ‘Microsoft.SPOT.Native’ (4.2.0.0)
Error: a3000000
Waiting for debug commands…
Das Programm “[3] Micro Framework application: Verwaltet” wurde mit Code 0 (0x0) beendet.
----------------- EDIT: found the errorlist^^
see image
