Virtual keyboard - Spider & TE35
Greetings…newbie here. Just got my FEX Spider and TE35 LCD. I’m working on a project and wondered if there is a way to use the TE35 LCD as a virtual keyboard to enter a name. I don’t need special characters…just letters.
I’ve seen some touchscreen examples on the web but they’re few and far between. Anyone done anything like that before?
Thank you
Welcome to the forum.
GHI provides a free library called Glide which contains a graphic keyboard. After a bit of reading about Glide, you should be able to
setup a keyboard.
http://www.ghielectronics.com/glide
Once you get the name from the “virutal keyboard” what are you going to do with it?
Thanks for the reply Mike…I’ll look into the Glide library. I’ve had some experience with an Atmel dev board with resistive touch so it should be a no brainer.
I actually developing a system wthat will send sensor data to a SQL server based on Michael Dodaro’s “Sending .NET Gadgeteer Sensor Data to a REST Web Service”. In his example, the user name is static. I am wanting to improve the process by allowing the user to key in a name and save that name as the userName variable. Nothing heavy duty, just making it a bit more flexible.
Thanks again
