I don’t know if it was there before, but I see these lines on the display when I draw directly or use Avalonia. Any ideas on what could be wrong?
I found the problem. It was a bad screen. I don’t know if I bought it that way or if I damaged it in handling, but its the screen. Woe is me. This is why I buy 3 of these things.
That looks well designed. What are you making?
3D printer. A big one.
Did you manage to sort out the hardware drivers for this as I recall you doing some PCB designs a few years ago. Is this still the same project that you started on a few years ago?
Mike is correct. A big 3d printer. At least it used to be big, but now the industry is catching up.
I had not previously sorted out the hardware stepper drivers, so I moved up to PowerStep01 from ST Micro and will use the off-the-shelf boards.
Sadly, it is still the same project I started (12 years) ago.
Can these screens be damaged by overclocking them? I’m getting a bad feeling that I’m damaging this new screen as well.
I doubt it but everything is possible I guess!
