Hello
I plan to use USB3 storage devices on netmicroframework using netmf 4.3SDK.
Are there any things to consider? In past I experienced, that not all USB2 storage devices have been correct detected.
Maybe there is a USB3 compatibility integrated in those devices.
Is this type of solution basically recommendable?
Regards
Herbert
Some very rare drives may have something special causing them to not work. Beside that 99.9% of devices should work just fine. If not, I am very curious why.
The MassStorage Event for DeviceDetection has not been invoked by the Framework. We decided to use other USB sticks.
@ hweinfurterAAEj4i5 - Do you know the USB ID of that stick? Or the manufacturer/product id? It might be worthwhile for future reference.
modern sandisk usb3.0 flash driver works fine
