Although I have used TinyCLR before I am using the UI features for the first time.
I am developing on the SCM20260D dev board with the final target being the FEZ Portal.
I have a logo that I want to put in a Stackpanel but I cannot find a way to do it.
I have read through many forum posts but none seem to cover this topic. In the code below I have an element called ‘LogoHolder’ which is currently just a rectangle as a placeholder but I want to replace it with an image of the same size.
I have looked at the ‘GHIElectronics.TinyCLR.UI.Media.ImageSource’ property but I can’t get it to work without the error:
Cannot implicitly convert type ‘System.Drawing.Bitmap’ to ‘GHIElectronics.TinyCLR.UI.Media.ImageSource’
Any help would be much appreciated
private static UIElement Elements(DisplayController display)
var panel = new StackPanel(Orientation.Vertical);
panel.HorizontalAlignment = HorizontalAlignment.Left;
//Load logo and fonts to be used
var image = Resources.GetBitmap(Resources.BitmapResources.FBBLogo);
var font10pnt = Resources.GetFont(Resources.FontResources.droid_reg10);
var LogoHolder = new GHIElectronics.TinyCLR.UI.Shapes.Rectangle
Width = 184,
Height = 28,
Fill = new SolidColorBrush(Colors.Red),
HorizontalAlignment = HorizontalAlignment.Left,
var separator = new GHIElectronics.TinyCLR.UI.Shapes.Rectangle
Width = display.ActiveConfiguration.Width,
Height = 10,
Fill = new SolidColorBrush(Colors.White),
var txt = new TextBox
Font = font10pnt,
Text = "AQ: 100%",
Foreground = new SolidColorBrush(Colors.Gray),
Height = 20,
Width = 100,
VerticalAlignment = VerticalAlignment.Center,
BorderThickness = 0
panel.Children.Add(LogoHolder);
panel.Children.Add(separator);
panel.Children.Add(txt);
return panel;
It does. We loaded many icons (images), for example the SD icon. That is a general case, so you will see some middle classes, but in the end, you will see how we add images to the UI
I understand this but this does not put that image into a panel or other UI Element. If I have a Stackpanel with textboxes, buttons and other elements how do I also include an image?
