I tried to blink a LED according to the tutorial. but the GHIElectronics.NETMF.FEZ; assembly is not there. I want to use the following codes. I have already installed the SDK4.2 and FEZ Cerbuino Bee board is used. Can any one give me a suggestion. please
OutputPort LED;
LED = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.LED, true);
LED.Write(!LED.Read());
Thread.Sleep(200);
As your board is a Gadgeteer mainboard, it is easier for you to use a Gadgeteer project and then use mainboard.SetOnboardLED(true);
Please use GHI.Hardware.FEZCerb namespace and assembly.
You will need GHI.Hardware.FEZCerb.Pin.PB2 for LED
Helpful link for you:
https://www.ghielectronics.com/docs/45/fez-cerbuino-bee-developer
the following namespace is missing in the references. can you please tell me how to insert it. thanks
The example is old. Please follow Gus’s advise or use the namespace/assembly and pin that I have indicated above.
Thanks mate. I just new to FEZ
We will update the example shortly
Does .net micro frame work has a hex conversion or do i need to include it in my codings
uint P32 = uint.Parse(“b7e15163”, System.Globalization.NumberStyles.HexNumber);
the following error is displayed due to the above statement
Error 1 The type or namespace name ‘NumberStyles’ does not exist in the namespace ‘System.Globalization’ (are you missing an assembly reference?)
which assembly do I need to avoid this error when using the .net frame work or does it need any number conversions???
There are some string conversion helpers on codeshare. I would use that.
NETMF doesn’t have all the functionality that exists in full .Net.
Using MSDN for .NET Micro Framework (The .NET Micro Framework References | Microsoft Learn) and following the link to System.Globalization Namespace implies that NETMF does not support “NumberStyles”. Additionally C# supports hexadecimal literal values of the form 0xHHHH:
uint P32 = 0xb7e15163;
See also: c# - converting string to uint - Stack Overflow
public void Encrypt(FileStream streamreader,FileStream streamwriter)
uint r1, r2;
System.IO.BinaryReader br = new System.IO.BinaryReader(streamreader);
System.IO.BinaryWriter bw = new System.IO.BinaryWriter(streamwriter);
long filelength = streamreader.Length;
while (filelength > 0)
try
r1 = br.ReadUInt32();
try
r2 = br.ReadUInt32();
catch
r2 = 0;
catch
r1 = r2 = 0;
Encode(ref r1, ref r2, rounds);
bw.Write(r1);
bw.Write(r2);
filelength -= 8;
Above code is used to encrypt a data file. I want to change it to encrypt a data stream (i.e data stream coming from a sensor). what are the changes I need to do???
Thanks Architect.
using GHI.Hardware.FEZCerb;
and
used in the example is perfect.
Joey
