Using G120 LCD pins as GPIOs
I am designing a custom board using the G120 and will not be using the RGB LCD connections. Can the port 1 pins be used as GPIOs? Do I need to do anything special to enable this mode on these pins?
No problem at all, easy as
I do set the LCD configuration to "other" in FEZ Config with all functions disabled.
Excellent!
