I’m using the Cobra case and 4.3" display and loving it, but one unfortunate thing. The reset button isn’t accessible if the Cobra is inside it.
What are the rest of you Cobra users doing? Can I just wire up a button to the Reset pin on the board? If I did do that, do I just connect it to ground when resetting or do I need add a resister?
@ Chris With the Cobra + 4.3" display you can’t power it up ith just USB there isn’t enough juice you have to power it externally… Pulling the USB cable doesn’t do anything…
I can run mine off the USB as well. Just playing it safe by having a 6-Volt power supply as recommended by GHI in the brochure. That really makes it a pain cause I have to unplug both to reset. Will wire up a switch as soon as I have a chance to pick one up.
