I am trying to use the character display module on a custom board using G120 module. The display module goes into the Y socket, thus wondering if the socket needs to be recreated on the custom board, or there is a simpler approach?
If creating of the socket Y is not an option, can I directly drive the Character Display via SPI?
All you need is few regular pins. Take a look at the driver source ad’s do a little reading online about these displays. No you can’t use spi. They are much simpler than that.
