hullie
March 7, 2011, 11:01am
1
Hi All,
I just can’t get DHCP to run, I get the following error:
An unhandled exception of type ‘System.Exception’ occurred in GHIElectronics.NETMF.W5100.dll
Additional information: Use Dhcp class,GHIElectronics.NETMF.W5100.Dhcp.dll
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\FEZDomino_GHIElectronics.NETMF.FEZ.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.W5100.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘D:\SVNWorkingFolder\sentul\Livepigeonflights\Micro.net\Network domino\Network domino\bin\Debug\le\FEZ Domino Application.exe’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.W5100.Dhcp.dll’
#### Exception System.Exception - 0x00000000 (1) ####
#### Message: Use Dhcp class,GHIElectronics.NETMF.W5100.Dhcp.dll
#### GHIElectronics.NETMF.Net.NetworkInformation.NetworkInterface::EnableDhcp [IP: 0006] ####
#### MySocketServer::Main [IP: 004a] ####
A first chance exception of type ‘System.Exception’ occurred in GHIElectronics.NETMF.W5100.dll
The program ‘[1] Micro Framework application: Managed’ has exited with code 0 (0x0).
Code is as follows:
using System.Text;
using GHIElectronics.NETMF.Net.Sockets;
using GHIElectronics.NETMF.Net.NetworkInformation;
using Socket = GHIElectronics.NETMF.Net.Sockets.Socket;
public static class MySocketServer
byte[] mac = { 222, 173, 190, 239, 254, 237 };
WIZnet_W5100.Enable(SPI.SPI_module.SPI1,
(Cpu.Pin)FEZ_Pin.Digital.Di10,
(Cpu.Pin)FEZ_Pin.Digital.Di9, true);
NetworkInterface.EnableDhcp(mac, "domino");
Anyone got an idea?
Best regards,
Jeroen
hullie
March 8, 2011, 3:41am
3
Thank you! It’s working now ;D
Did you get to the bottom of it? There is nothing in beta docs about not using NetworkInterface. Just curious.
The unused DHCP methods in NetworkInterface are going to be removed, in the next release.
Thanks Joe! Good to know.
Just curious,
Does the new dhcp functionality retrieves/updates the dns server information as well as the ip address/mask/gateway ?
[quote]Does the new dhcp functionality retrieves/updates the dns server information as well as the ip address/mask/gateway ?
[/quote]
Yes it does that.
