Hi Brett,
I just want to clarify that currently I have 4.3 .net micro framework and I got below firmware
in the device :
Loader (TinyBooter) version information:
4.3.4.0 on this computer.
4.3.4.0 on this device.
The Loader (TinyBooter) is up to date. <<<
Firmware (TinyCLR) version information:
4.3.5.0 on this computer.
4.3.5.0 on this device.
The Firmware (TinyCLR) is up to date. <<<
Before I had code written in 4.2 and all the references of the 4.2
Now, I got 4.3 , so should I be able to use references of 4.2 because my code has written in 4.2 ?
Currently, I am getting following error in output window, I am not sure how could I solve the issue ?
Found debugger!
Create TS.
Loading start at a0e68ea4, end a0e98338
Assembly: mscorlib (4.3.1.0) Assembly: Microsoft.SPOT.Native (4.3.1.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.3
.1.0) Assembly: System.Security (4.3.1.0) Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0) Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0) Assembly: System.IO (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0) Assembly: Microsoft.SPOT.Touch (4.3.1.0)
Assembly: Microsoft.SPOT.Ink (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Attaching deployed file.
Assembly: GHI.Premium.System (4.2.11.1) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.G400HDRBreakout (4.3.5.0) Attaching deployed file.
Assembly: MFDpwsExtensions (4.3.1.0) Attaching deployed file.
Assembly: GHI.Premium.USBHost (4.2.11.1) Attaching deployed file.
Assembly: GHI.Hardware (4.3.5.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Hardware.OneWire (4.3.1.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZCerberus (4.3.5.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZHydra (4.3.5.0) Attaching deployed file.
Assembly: Gadgeteer.DaisyLink (2.43.1.0) Attaching deployed file.
Assembly: System.Net.Security (4.3.1.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Wireless.IEEE_802_15_4.Phy (4.3.1.0) Attaching deployed file.
Assembly: MFUpdate (4.3.1.0) Attaching deployed file.
Assembly: GHI.Premium.Net (4.2.11.1) Attaching deployed file.
Assembly: Microsoft.SPOT.Wireless.IEEE_802_15_4 (1.0.0.0) Attaching deployed file.
Assembly: GHI.Usb (4.3.5.0) Attaching deployed file.
Assembly: GHI.Glide (4.3.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Wireless.IEEE_802_15_4.Mac (4.3.1.0) Attaching deployed file.
Assembly: MFWsStack (4.3.1.0) Attaching deployed file.
Assembly: MFDpwsClient (4.3.1.0) Attaching deployed file.
Assembly: GHI.Premium.USBClient (4.2.11.1) Attaching deployed file.
Assembly: Microsoft.SPOT.Net.Security (4.3.1.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZRaptor (4.3.5.0) Attaching deployed file.
Assembly: System (4.3.1.0) Attaching deployed file.
Assembly: GHI.Premium.IO (4.2.11.1) Attaching deployed file.
Assembly: Toolbox.NETMF.Core (4.2.0.0) Attaching deployed file.
Assembly: Gadgeteer.SPI (2.43.1.0) Attaching deployed file.
Assembly: Gadgeteer.WebServer (2.43.1.0) Attaching deployed file.
Assembly: GHI.SQLite (4.3.5.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZSpider (4.3.5.0) Attaching deployed file.
Assembly: MFDpwsDevice (4.3.1.0) Attaching deployed file.
Assembly: GHI.Premium.Hardware (4.2.11.1) Attaching deployed file.
Assembly: System.Ftp (4.3.1.0) Attaching deployed file.
Assembly: System.Xml.Legacy (4.3.1.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Update (4.3.1.0) Attaching deployed file.
Assembly: Microsoft.VisualBasic (1.0.0.0) Attaching deployed file.
Assembly: GHI.Hardware.G120 (4.2.11.1) Attaching deployed file.
Assembly: Gadgeteer.Serial (2.43.1.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZCerbuinoBee (4.3.5.0) Attaching deployed file.
Assembly: Gadgeteer.WebClient (2.43.1.0) Attaching deployed file.
Assembly: GHI.Networking (4.3.5.0) Attaching deployed file.
Assembly: System.Http (4.3.1.0) Attaching deployed file.
Assembly: powercloud (1.0.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Wireless.IEEE_802_15_4.Phy.CC2420 (4.3.1.0) Attaching deployed file.
Assembly: Gadgeteer (2.43.1.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Time (4.3.1.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZCobraIIEco (4.3.5.0) Attaching deployed file.
Assembly: mfnet.smallbiz.common (1.0.0.0) Attaching deployed file.
Assembly: GHI.Pins (4.3.5.0) Attaching deployed file.
Assembly: System.Text.RegularExpressions (4.3.1.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.3.1.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZCerbuinoNet (4.3.5.0) Attaching deployed file.
Assembly: System.Xml (4.3.1.0) Resolving.
Assembly: GHI.Premium.System (4.2.11.1) needs assembly âmscorlibâ (4.2.0.0)
Assembly: GHI.Premium.System (4.2.11.1) needs assembly âMicrosoft.SPOT.Hardwareâ (4.2.0.0)
Assembly: GHI.Premium.System (4.2.11.1) needs assembly âMicrosoft.SPOT.Nativeâ (4.2.0.0)
Assembly: GHI.Premium.USBHost (4.2.11.1) needs assembly âmscorlibâ (4.2.0.0)
Assembly: GHI.Premium.USBHost (4.2.11.1) needs assembly âGHI.Premium.Systemâ (4.2.11.1)
Assembly: GHI.Premium.USBHost (4.2.11.1) needs assembly âMicrosoft.SPOT.Hardwareâ (4.2.0.0)
Assembly: GHI.Premium.USBHost (4.2.11.1) needs assembly âMicrosoft.SPOT.Graphicsâ (4.2.0.0)
Assembly: GHI.Premium.Net (4.2.11.1) needs assembly âMicrosoft.SPOT.Nativeâ (4.2.0.0)
Assembly: GHI.Premium.Net (4.2.11.1) needs assembly âmscorlibâ (4.2.0.0)
Assembly: GHI.Premium.Net (4.2.11.1) needs assembly âMicrosoft.SPOT.Netâ (4.2.0.0)
Assembly: GHI.Premium.Net (4.2.11.1) needs assembly âMicrosoft.SPOT.Hardwareâ (4.2.0.0)
Assembly: GHI.Glide (4.3.0.0) needs assembly âSystem.Xmlâ (4.3.1.0)
Assembly: MFWsStack (4.3.1.0) needs assembly âSystem.Xmlâ (4.3.1.0)
Assembly: MFDpwsClient (4.3.1.0) needs assembly âMFWsStackâ (4.3.1.0)
Assembly: MFDpwsClient (4.3.1.0) needs assembly âSystem.Xmlâ (4.3.1.0)
Assembly: GHI.Premium.USBClient (4.2.11.1) needs assembly âmscorlibâ (4.2.0.0)
Assembly: GHI.Premium.USBClient (4.2.11.1) needs assembly âMicrosoft.SPOT.Hardware.Usbâ (4.2.0.0)
Assembly: GHI.Premium.USBClient (4.2.11.1) needs assembly âGHI.Premium.IOâ (4.2.11.1)
Assembly: GHI.Premium.USBClient (4.2.11.1) needs assembly âMicrosoft.SPOT.Nativeâ (4.2.0.0)
Assembly: GHI.Premium.IO (4.2.11.1) needs assembly âmscorlibâ (4.2.0.0)
Assembly: GHI.Premium.IO (4.2.11.1) needs assembly âGHI.Premium.Systemâ (4.2.11.1)
Assembly: Toolbox.NETMF.Core (4.2.0.0) needs assembly âmscorlibâ (4.2.0.0)
Assembly: Toolbox.NETMF.Core (4.2.0.0) needs assembly âMicrosoft.SPOT.Hardwareâ (4.2.0.0)
Assembly: MFDpwsDevice (4.3.1.0) needs assembly âMFWsStackâ (4.3.1.0)
Assembly: MFDpwsDevice (4.3.1.0) needs assembly âSystem.Xmlâ (4.3.1.0)
Assembly: GHI.Premium.Hardware (4.2.11.1) needs assembly âmscorlibâ (4.2.0.0)
Assembly: GHI.Premium.Hardware (4.2.11.1) needs assembly âMicrosoft.SPOT.Hardwareâ (4.2.0.0)
Assembly: GHI.Premium.Hardware (4.2.11.1) needs assembly âGHI.Premium.Systemâ (4.2.11.1)
Assembly: GHI.Hardware.G120 (4.2.11.1) needs assembly âmscorlibâ (4.2.0.0)
Assembly: powercloud (1.0.0.0) needs assembly âGHI.Premium.Netâ (4.2.11.1)
Assembly: powercloud (1.0.0.0) needs assembly âmfnet.smallbiz.commonâ (1.0.0.0)
Assembly: powercloud (1.0.0.0) needs assembly âGHI.Premium.Hardwareâ (4.2.11.1)
Assembly: powercloud (1.0.0.0) needs assembly âGHI.Premium.IOâ (4.2.11.1)
Assembly: powercloud (1.0.0.0) needs assembly âMicrosoft.SPOT.Hardwareâ (4.2.0.0)
Assembly: powercloud (1.0.0.0) needs assembly âMicrosoft.SPOT.Netâ (4.2.0.0)
Assembly: powercloud (1.0.0.0) needs assembly âmscorlibâ (4.2.0.0)
Assembly: powercloud (1.0.0.0) needs assembly âToolbox.NETMF.Coreâ (4.2.0.0)
Assembly: mfnet.smallbiz.common (1.0.0.0) needs assembly âmscorlibâ (4.2.0.0)
Assembly: mfnet.smallbiz.common (1.0.0.0) needs assembly âMicrosoft.SPOT.IOâ (4.2.0.0)
Assembly: mfnet.smallbiz.common (1.0.0.0) needs assembly âMicrosoft.SPOT.Nativeâ (4.2.0.0)
Assembly: mfnet.smallbiz.common (1.0.0.0) needs assembly âSystemâ (4.2.0.0)
Error: a3000000
Waiting for debug commandsâŚ
The program â[38] Micro Framework application: Managedâ has exited with code 0 (0x0).
