We use a FEZ Domino with a program that was built for FEZ Panda II. For configuration there is a litte Windows program that communicate over USB with the device. Here we use StartCDC_WithDebugging() on COM2 and with FEZ Panda it works. But with FEZ Domino the program runs but no COM port will be installed when we plug the device.
In an other thread leforban respond “You can’t use CDC AND debug over USB since firmware V4.2. If you use CDC you need to force the debug interface being COM1. This is usually done using a button or a jumper.”
Thats why I try to use StartCDC() without debugging but then I get an exception:
Could it be a Problem with COM2? We can’t find any documents of FEZ Domino that shows something about the COM-ports. We can’t use COM1 because this is used for communication with GPRS.
No I mean the COM2 of the FEZ Domino. My Problem is that I can’t see a COM-Port on PC.
This document I know but there is no document to find for the pinout of the FEZ Domino.
Do you know which COM-Port is used for the CDC-Interface? On FEZ Panda it is COM2 but I don’t know if it is also for FEZ Domino. Maybe it is the reason why no COM-port is shown on PC.
I need COM1 for communication with GPRS shield. I have to see if it works with an other COM port.
Meanwhile I wrote a litte test program where COM1 not used. when I start it now the PC wants to install serial driver for USBizi and CDC VCom. It look great!
But my Problem is that the PC can’t find any driver.
On by HDD I have USB driver under
GHI Electronics\GHI USB Drivers\ and
GHI Electronics\GHI NETMF v4.1 SDK\USB Drivers\
but they don’t work.
Usually only 1 COM port is used for serial debug. If COM1 is right one, COM2 won’t work. also, if COM2 work, COM1 won’t, unless I am missing something.
That driver should be under USB Driver folder. But I see your PC has not English language. I remember somewhere has same problem with these PC setting.
I tried to update the driver manually. I loaded the driver in GHI Electronics\GHI NETMF v4.1 SDK\USB Drivers\ and get the message: A driver for this device is found but during Installation an error occurs".
