I’m a bit new to USB client interactions, but here’s the background:
I have a FPGA that is connected to my RC transmitter decoding it’s PPM signal.
The NETMF target reads the transmitter stick/switch (button) values from the FPGA over i2c. That part is totally working.
What isn’t yet is the UsbClient portion of the project. I would like for my netmf target to show up in Windows as a USB joystick relaying the values from my transmitter.
The configuration is as follows:
4 Axises (elevator, aileron, throttle, rudder) I would like these to come out on the USB joystick side with -512 to 512 precision. That would make each axis a 16bit value.
2 switches on the transmitter which will show up as simple buttons.
So, then next bit is that I need to get the client descriptors written, see attached for that image.
Does anyone see anything wrong with my current configuration?
Please speak up if you have any suggestions, too. ;D
