Ok - in working further on the camera issue, I wrote a new app to see if I could get the USB Host to work.
I implemented using USBHostController rather than the Gadgeteer modules.
Hardware is set up with USBClientDP + external power on 1, USB Host module on 3 - nothing else attached.
When I insert a USB device (I’ve tried 3 so far - 2 thumb drive, 1 gps), I invariably get a BadConnectionEvent. The device struct that is passed in is essentially empty (all values 0, except INTERFACE_INDEX is 255 (-1).
So - The host code recognizes that something was plugged in, but apparently can’t communicate enough to get any further.
Any suggestions on digging deeper on this?
The program debug output is:
starting
last error: 0
No devices
bad connect event:
USB Device: (Type: 0:0:0:255:0:0)
And - I figured out how to flash the main board green LED :^)
namespace EMX_Application1
using GHIElectronics.NETMF.USBHost;
static bool connected = false;
Debug.Print("starting");
USBHostController.DeviceDisconnectedEvent += new USBH_DeviceConnectionEventHandler(USBHostController_DeviceDisconnectedEvent);
USBHostController.DeviceBadConnectionEvent += new USBH_DeviceConnectionEventHandler(USBHostController_DeviceBadConnectionEvent);
System.Threading.Thread ledThread = new Thread(AnotherThread);
ledThread.Start();
int cnt = 0;
if (connected)
Debug.Print("connected " + cnt.ToString());
++cnt;
USBH_ERROR err = USBHostController.GetLastError();
Debug.Print("last error: " + err.ToString());
int idx = 0;
foreach (USBH_Device device in USBHostController.GetDevices())
Debug.Print("device " + idx.ToString());
PrintDevice(device);
++idx;
if (idx == 0)
Debug.Print("No devices");
Thread.Sleep(60000);
static void USBHostController_DeviceBadConnectionEvent(GHIElectronics.NETMF.USBHost.USBH_Device device)
Debug.Print("bad connect event:");
static void USBHostController_DeviceDisconnectedEvent(GHIElectronics.NETMF.USBHost.USBH_Device device)
Debug.Print("disconnect " + device.ID.ToString());
static void USBHostController_DeviceConnectedEvent(GHIElectronics.NETMF.USBHost.USBH_Device device)
static void PrintDevice(USBH_Device device)
Debug.Print("USB Device: (Type: "
+ device.TYPE.ToString()
+ ":" + device.VENDOR_ID.ToString()
+ ":" + device.PRODUCT_ID.ToString()
+ ":" + device.INTERFACE_INDEX.ToString()
+ ":" + device.PORT_NUMBER.ToString()
+ ":" + device.ID.ToString()
static void AnotherThread()
OutputPort op1 = new OutputPort(EMX.Pin.IO47, false);
bool state = false;
op1.Write(state);
if (state)
Thread.Sleep(250);
Thread.Sleep(750);
state = !state;
