I have updated a program from the firmware 4.2 to 4.3. This is a raw device that has 2 endpoints, one to send and one to get data. The problem is that now, with the 4.3 version, when no data are coming from the device, the methods transfer is not returning, and my thread stay there forever.
Where my 4.3 code is not returning :
static RawDevice.Pipe adbInPipe;
static byte[] adbData = new byte[65];
static void myFunction()
int count = 0;
try
count = adbInPipe.Transfer(adbData, 0, adbData.Length); //Where my program is not returning from when no data are coming from the device.
catch (Exception ex)
Debug.Print(ex.ToString());
//Do some stuff according to the reading.
While in 4.2 it would just return 0, and continue in my code.
static USBH_RawDevice.Pipe adbInPipe;
int count = 0;
try
count = adbInPipe.TransferData(adbData, 0, adbData.Length); //If there is no data sent from the device, the TransferData return 0, and my code continue.
In both case the methods is in a thread called once the device in connected.
If I try to step-In the transfer methods, the output returns this:
And it keeps printing “Transfer → Transfer → TransferTimeout.get → Transfer → Transfer → Endpoint.get” forever.
Changing the timeout in the pipe object does not seem to have an effect.
If anyone has some advice or idea of what to do, this would be great, because I have no clue what to do now about this. (Apart from sticking with 4.2 firmware.)
