Hi.
I would like to know if it’s possible to use the USB Host feature, which is inside the LPC2387 onboard of the FEZ Panda.
If the diode, protecting the 5V power supply is removed, it is possible to power a USB device - but I haven’t been able to start a communication. Does the resistors and the “pull-up” enabler on D+ has something to do with this?
Or are the pull-down resistors, which are on the Domino, required?
Or should you disable the USB-debug feature first?
This is the code I’ve tried on the FEZ Panda, which deploys fine btw.
using System.IO;
using Microsoft.SPOT.IO;
using GHIElectronics.NETMF.USBHost;
namespace FEZ_Panda_Application1
static bool ledState = false;
static OutputPort led = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.LED, ledState);
// Subscribe to RemovableMedia events
//RemovableMedia.Insert += RemovableMedia_Insert;
//RemovableMedia.Eject += RemovableMedia_Eject;
// Subscribe to USB events
USBHostController.DeviceConnectedEvent += DeviceConnectedEvent;
// Sleep forever
static void DeviceConnectedEvent(USBH_Device device)
if (device.TYPE == USBH_DeviceType.MassStorage)
//Debug.Print("USB Mass Storage detected...");
ledState = !ledState;
led.Write(ledState);
Best Regards
Thomas Jespersen
