USB Host Events
Hi Everyone,
I’m really keen to find a solution to this.
I’m using the sd card and usb host. The usb host event won’t fire when the mouse is in the socket when the code starts. I have to remove and re-insert it to use the mouse.
I’ve tried variations in code but it simply won’t fire. It works without the sd card module.
There will be no access to the usb host.
I’d be really thankful for any solutions - right now I’m thinking to add a relay switch to the power of the usb but it’s a last resort.
hey there, it’s probably worth giving a code example of the minimum required to repro this so we know how to test for it. Probably also worth telling us a 4.1 or 4.2 project, and what mainboard you’re using.
Thanks Brett.
I’m on 4.1 and am using the FEZ spider.
This is my code - I’ve tried putting the mouse connected event else were but it makes no difference. I remember having a similar issue before with the camera connected event. Hopefully it’s not silly coding!
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using GHIElectronics.NETMF.USBHost;
using GHIElectronics.NETMF.USBClient;
using Gadgeteer.Modules.Seeed;
namespace ScreenMovement
    public partial class Program
        USBH_Mouse mouse;
        float Scale = 0.5f;  // set mouse scale and sensitivity
        static int Xmin = 0; // set the boundaries according to the image size
        static int Ymin = 0;
        int Xmax;
        int Ymax;
        int x; // mouse x coordinate
        int y; // mouse y coordinate
        GT.StorageDevice sd;
        int screenWidth;
        int screenHeight;
        Bitmap picture;
            screenWidth = (int)oledDisplay.Width;
            screenHeight = (int)oledDisplay.Height;
            sdCard.SDCardMounted += new SDCard.SDCardMountedEventHandler(sdCard_SDCardMounted);
        void sdCard_SDCardMounted(SDCard sender, GT.StorageDevice SDCard)
            Debug.Print("Card Mounted");
            // red when not loaded
            oledDisplay.SimpleGraphics.DisplayRectangle(GT.Color.Red, 0, GT.Color.Red, 0, 0, (uint)screenWidth, (uint)screenHeight);
            sd = SDCard;
            string fileName = "\\ProtoPictures\\picture.jpg"; // file name
            picture = sd.LoadBitmap(fileName, Bitmap.BitmapImageType.Jpeg);
            // green when loaded
            oledDisplay.SimpleGraphics.DisplayRectangle(GT.Color.Green, 0, GT.Color.Green, 0, 0, (uint)screenWidth, (uint)screenHeight);
            Debug.Print("Picture Loaded");
            usbHost.MouseConnected += new UsbHost.MouseConnectedEventHandler(usbHost_MouseConnected);
        void usbHost_MouseConnected(UsbHost sender, USBH_Mouse mouse)
            Debug.Print("Mouse Connected");
            mouse.Scale(Scale);
            mouse.SetCursor(picture.Width / 2, picture.Height / 2); // center the mouse to begin with
            this.mouse = mouse;
            mouse.MouseMove += new USBH_MouseEventHandler(mouse_MouseMove);
            showImage();
        void showImage() // show image to start without the event
            x = picture.Width / 2;
            y = picture.Height / 2;
            scrollImage(x, y);
        void mouse_MouseMove(USBH_Mouse sender, USBH_MouseEventArgs args)
            Xmax = picture.Width - screenWidth;
            Ymax = picture.Height - screenHeight;
            mouse.SetCursorBounds(Xmin, Xmax, Ymin, Ymax);
            Debug.Print(mouse.Cursor.X.ToString() + " , " + mouse.Cursor.Y.ToString());
            x = mouse.Cursor.X;
            y = mouse.Cursor.Y;
            scrollImage(x, y);
        void scrollImage(int x, int y)
            Bitmap croppedImage = new Bitmap(128, 128);
            croppedImage.DrawImage(0, 0, picture, x, y, screenWidth, screenHeight);
            oledDisplay.SimpleGraphics.DisplayImage(croppedImage, 0, 0);
            croppedImage.Clear();
