It is possible theoretically but you will be using all your system resources…and with PPP it will be too much. FEZ Cobra can do all that and a lot more with ease
There is no PPP there for sure! Lwip is part of standard NETMF PK build so this is not specific to any device. But if you note, that the board you pointed out has much less software libraries than GHI’s firmware and it is still already using most of its memory due to having lwip stack (it doesn’t even have crypto libs in standard build). GHI have looked into this before and we decided that lwip + the other features added will simply be more than system available resources. For that, there is EMX/FEZ Cobra.
Ah you’re right there is no PPP. For sure there is more libs on the Domino (that’s why I have one), but I think they had a good idea : They have 2 firmwares : With and without networking.
I think I will buy a Cobra someday but I can’t for now…
GHI’;s firmware with networking and all the features leaves your domino with plenty of resources There is no need to make 2 firmware versions for domino
You could use uip on RLP and write a small PPP version. I’ve done it in the past on a HC11 using less than 10K… its a little tricky to use uip as it does not rely on multitasking but it does the work.
