I am getting occasional USB read/write errors. Has anyone experienced anything like this. When the code below is executed sometimes the bytes read back are 0 instead of 4. This only happens once in a while and it appears that the USB connection is interrupted… At first we thought it was a noise problem with the USB bus, but now we have a very low noise environment and it is still occurring.
What are you connecting to? Does it draw a lot of power?
I had problems when writing the XBox360 controller driver with my USB port not being able to supply enough power to run both rumble motors at full power. I had the same issues you were describing as the device browned out.
