Usb endpoint0
Hello.
I am writing the code of the usb client.
I found a lot of sample codes which used endpoint1 and endpoint2.
However, I want to use endpoint0.
Does not anyone know?
You understand that EP0 is used for control transfers right? Why do you need EP0?
Yes, understands.
For instance, I want to respond to the standard request that it should be supported by the USB printer class.
It is done through EP0.
Look at the USBH_RawDevice class. There is SendSetupTranfer(…). It takes standard parameters for EP0 transfers
Thank you for some replies.
I want to respond to a standard request as USB client.
Not USB Host.
Sorry.
It is Class-Specific Requests.
It is not a standard request.
Oh, I missed that.
Unfortunately, it is not possible for the client. Accessing EP0 needs advanced functionality. NETMF doesn’t support it.
That’s too bad.
I think that .NETMF should be able to do it.
