Hello
I want to execute some code on removableMedia.Eject event
but when I remove the usb This Occurs :
what is the problem?
thanks
Hello
thanks
Please provide a complete minimal example showing this behavior.
ok this is my code:
private void rfid_CardIDRecieved(RFIDReader sender, string ID)
if (!processing)
RenderUIView(UIView.LoginView);
try
byte[] passData = System.Text.Encoding.UTF8.GetBytes(ID);
WebRequest request = WebRequest.Create(URLHelper.ConfigInfoURL);
request.Method = "POST";
request.ContentType = "application/x-www-form-urlencoded";
request.ContentLength = passData.Length;
#region Add Headers
request.Headers.Add("RFID", ID);
#endregion
Stream dataStream = request.GetRequestStream();
dataStream.Write(passData, 0, passData.Length);
dataStream.Close();
WebResponse response = request.GetResponse();
string userName = ((HttpWebResponse)response).Headers["UserName"];
response.Close();
if (userName != "unAuthenticatedUsers")
RFIDIsValid = true;
txtuserName = new Text(fnt, userName);
Canvas.SetTop(_HomeViewLogo, 5);
Canvas.SetLeft(_HomeViewLogo, 70);
canvas.Children.Add(txtuserName);
Canvas.SetLeft(txtuserName, txtuserNameX);
Canvas.SetTop(txtuserName, txtuserNameY);
_UserRFID = ID;
RenderUIView(UIView.InsertUSBView);
processing = true;
else if (userName == "unAuthenticatedUsers")
RFIDIsValid = true;
txtuserName = new Text(fnt, "Unauthenticated User");
_UserRFID = ID;
processing = true;
RFIDIsValid = false;
txtuserName = new Text(fnt, "not valid...");
txtuserName.Visibility = Visibility.Visible;
canvas.UpdateLayout();
catch
processing = false;
public void RemovableMedia_Insert(object sender, MediaEventArgs e)
if (RFIDIsValid)
try
savedVolInfo = e.Volume;
rootDirectory = savedVolInfo.RootDirectory;
catch(Exception ex)
Debug.Print(ex.StackTrace);
public void RemovableMedia_Eject(object sender, MediaEventArgs e)
try
rootDirectory = "";
catch { }
that is your code, not a minimal example - please test an example that doesn’t rely on your RFID card reader but still shows the situation.
no matter… this is a very simple example :
using System.Collections;
using Microsoft.SPOT.Touch;
using Microsoft.SPOT.IO;
using System.IO;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace GadgeteerApp1
public partial class Program
int Number = 0;
RemovableMedia.Insert += RemovableMedia_Insert;
RemovableMedia.Eject += RemovableMedia_Eject;
Number++;
Number--;
That error again occurs…
Actually this dialog box appears :
@ Ehsan Ansari - What board are you using and what modules are connected in the designer?
@ John -
It is a Raptor with following modules :
USB Host
Ethernet ENC28
USB Client DP
Displat T35
RFID Reader
SD Card Module
@ Ehsan Ansari - This should be fixed in the next SDK.
