I am using the EMX for a data logger, which runs unattended in the field
If there is a corruption on the USB drive.
And I do a directory delete. The board hangs.
And it happens every time.
If I take and put the flash drive on a system that is running Windows Ce or my PC. I am able to delete the directory.
The file system depend on itself being in a healthy structure. If this structure got corrupted, like you said, I understand if it crashed.
The solution is to make sure files are closed gracefully…
That is true; but there is a posiblity the file would become corrupted in the field; Just thought of recovering without formating the drive. Because the directory is erasable from a Windows CE box or a PC.
