Sorry if this is a really obvious question, but I haven’t used the gadgeteer for a while! I’m having a problem knowing what to expect when trying to upgrade to the latest 2014 R1 package for Gadgeteer.
I have a FEZ Spider Mainboard, and had installed 2013 R3 on my main PC a while ago.
I then installed 2014 R1 onto a laptop, and FezConfig indicated that the TinyCLR firmware version was out of date (version on PC: v4.2.11.2, version on mainboard: v4.2.11.1).
That’s fine - but before I put the firmware, I went to check on my main PC. At this stage I wasn’t sure if 2014 R1 was on it, or 2013 R3. Anyway, on the main PC, FezConfig said everything was up to date (version on PC: v4.2.11.2, version on mainboard: v4.2.11.1), indicating this has 2013 R3.
So, I tried to install 2014 R1 on the main PC, to ensure everything is up to date and so that it works on both this and the laptop.
When I tried to install it, over the top of 2013 R3, every package installer simply asks ‘Repair or Remove’. I had assumed it would just update the packages. Not being sure what you’re supposed to do, I chose ‘Repair’ for all packages. But FezConfig still indicates firmware is up to date, so it looks like 2014 R1 didn’t get installed.
Are you supposed to actually say ‘Remove’, and does the installer then put the updated package on? Or do you have to uninstall all packages somehow, and then start totally from scratch?
I’ve tried to search the forums and website for a possible answer, but I can’t find any description of what exactly the procedure is to upgrade. Normally I’d expect it just to update the existing version automatically, rather than ask ‘Repair/Remove’. However, if it’s normal that you need to uninstall, or that you need to say Remove and have it then uninstall then install the updated package, it would be good if this was stated somewhere obvious. Perhaps I’ve overlooked it?
In case this is not actually normal behaviour, and is a problem, my system is Windows 8.1 64 bit, and I’m using VS2012.
Hope someone can help!
cheers,
