Under Properties -> Application I changed from “Micro Framework 3.0” to “Micro Framework 4.1” but have an error CLR_E_ENTRY_NOT_FOUND. Could someone please point me to a good source of steps required to upgrade projects? Thanks.
Hey KG1, welcome to the forum
Personally given the size of change since 3.0 I would create a new 4.1 project and move over individual code pieces as you go, and see what fundamental changes are required as you load each one.
Thank you Brett. I have just completed checking each library replacement (properties). All were ok except a local reference which l did not change originally. I removed it and reselected it and everything compiled ok! Nothing changed in the library properties but it did the trick. Thanks.
