hello,
for a reason or another when i tried to play with the Compass Module from seeedstudio and loaded the solution that came with the sourc using the VS debug mode, my display went White with the following on the Output:
Updating display configuration. DEVICE WILL NOW REBOOT. Visual Studio might lose connection, and debugging might need to be manually restarted.
and now my display can’t be used even after a reset… and power cycle doesn’t cure it either…
the only way to get back is to load another solution that i have opened which causes the same thing to display and the screen works again.
what is that all about?
