As we have been discussing on another thread in this same section of the forum, this sort of issue should not be happening. Someone else also pointed out that there was others with dead Cobra 2 boards with the latest 4.3 update.
Out of interest, I have two Cobra 2 boards sitting on the shelf so I decided to try and see if I could get that to work and updated to 4.3. The update seems to work as it updates and reboots and it shows up in Device Manager as a “GHI NETMF Interface: but Fez config when I try a check for update reports " Failure - Device is not connected or not responding”
Every few seconds the device does a disconnect and reconnect on USB and often appears as an UNKNOWN DEVICE. I am connected to external DC power too.
Looks like I have a non-working Cobra 2 myself now
Dave you described my scenario exactly. I actually have the Cobra II (WiFi) board which is discontinued. Not sure if that has anything to do it.
But as you described the Connecting/Disconnecting every minute or so is happening. While in FEZ Config, I see it appear for a few seconds, but never long enough for me to push an update before the device is no longer found.
@ John@ GHI, does this mean there’s a real issue? Is it a reason not to update to 4.3 on these devices just yet? Potential impact on G120 or is it just Cobra ?
@ Brett. I can confirm that it is not just Cobra 2 as I just tried to update a G120 based custom board and it is stuck in the same infinite loop.
I then tried the manual method to update TinyBooter on the custom G120 board and was able get the boot loader installed and it sat there for about 5 mins without resetting.
Then I installed the firmware and then I could update the LCD, do a reboot clr and now I have the LCD working and it’s ready for deployment.
I then tried the same procedure on my other custom G120 and it works too…
Something in Fezconfig is falling over if you don’t update the Tinybooter at the same time manually.
Lastly I tried this with my Cobra 2 board and it is now working too.
But it has NET 4.2.
I tried to update to 4.3 without luck.
Right now it only has the TinyBooter V1.1
Looks like the version is very old.
And the USB enumerates as a COM port.
As per your manual if the modes etc are left floating it should come up with USB but it does not.
I do not know how to proceed. I have spend a whole day on this now.
It says BAD FIRMWARE not no firmware. That’s somewhat different…
Because you erased the device, there’s no firmware active on it. That’s why it won’t come up and be visible as a USB device but just shows up as a COM port. This is not a problem. You should however use FezConfig to connect to the board via USB not via serial; can you show us a screen shot of FezConfig doing that please?
The other thing to make sure is you use the 1K method when sending the bootloader file; if you don’t you may get corruption. https://www.ghielectronics.com/docs/54/loader-tinybooter-g120-and-emx-families You may also have overwritten the file and caused an issue there too and you may have to repair/reinstall the GHI SDK to get the file back.
1: If someone can point me how to wire the touch screen it will help
2: Is there any way to speed up the boot up time. There is a 15 sec wait before the code runs
using System.Collections;
namespace MFConsoleApplication2
// The font object from a resource
Font font = Resources.GetFont(Resources.FontResources.cambriaBold);
Bitmap LCD = new Bitmap(SystemMetrics.ScreenWidth,
SystemMetrics.ScreenHeight);
//clears the memory and not the display
LCD.Clear();
//draw on memory
LCD.DrawLine(Colors.Green, 1, 10, 10, 40, 40);
// Draw to the screen buffer, not the screen
LCD.DrawText("Hello World!", font, Colors.Yellow, 100, 100);
// Flush the buffer ot the display
LCD.Flush();
```cs][/code
Which LCD are you using? If this is any of the GHI ones then they connect to a T socket as they use the internal ADC of the CPU to read the touch.
I am seeing the same issue with a G400 and G120 based boards. Previous firmware was fast but now with 4.3 I am seeing the same 10+ seconds boot time before I see the LOADING image appear.
I’ve even used the REBOOT CLR option in FEZCONFIG and it will takes time now to boot.
I don’t see this. 4.3 does boot a little slower for me and the boot up image I use does flicker a bit, but the startup time is nothing like 10seconds. Maybe its just related to a particular assembly.
@ microt - for G120 based boards you could try to start FezConfig and select from the menu “Advanced” -> “Reboot CLR” after that boot should be significant faster
