hi,
I have new FEZ main board, iwant to update it,
I use the new tool https://www.ghielectronics.com/docs/127/firmware-tinyclr-update
but after I updates (the tool read the version and says it is uo to date)
my network doesn’t work.
I tried to use both the built-in ethernet, and ENC28 ethernet -they are both don’t reply.
before update- my network replied pings.
only after update, it stopped.
I updated via advanced->FEZ spider,
and tried also the default tab of “update firmware”.
maybe that is the problem, but don’t understand the syntax of the mac.
in the tool written: 0-21-3-0-0-2.
on the board: 0021038046DD,
how should I write right to update?
@ Architect- try tp u[date, but the gadgeteer doesn’t answer,
I get: “Destination host unreachable”.
maybe it something in the wifi pass phrase or something else, even if I don’t use it ?
hi,
I solved it,
I found out, I don’t have to change the MAC address.
the flow I do:
update the network settings.
reboot CLR.
deploy my HEX file
and it brings ping.
